Best implement for road grading, for a 40HP CUT, regardless of cost?
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #21
Picked the picture from the INTERNET.:)
Back when there were a lot of four wheel pull type graders. Also some tractors were extended and a blade mounted in the middle.
There were also side discharge elevating scrapers that moved the dirt from the ditch to the road.
If you go looking for land planes a current manufacturer should show up.:thumbsup:
Land plane?? :)
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #23
I got a Boxblade, Landscape rake, and a Rear blade with custom gauge wheels. I have to say that out of all of them, i like the rear blade the best. They all have their purposes but for just grading gravel, the rear blade is #1. If there are a lot of pot holes, the boxblade typically works better and if there are a lot of larger rocks mixed in, then the landscape rake works better. It all depends on your road. I dont only grade 1 driveway, but actually 2 so i needed all these to get the job done. :thumbsup:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #24
I like that one!
Bit of a cross wind there Eh.
Yeah! That's what came up when I typed "land plane" into Google Images.
This one too:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #29
This one too:
Man!, that thing must have had rabies and someone put it out its misery:laughing:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #30
whether you choose a box blade or a scraper (angle) blade...the most valuable asset you can buy is a hydraulic top link...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
71069 (A49346)
71069 (A49346)
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
71061 (A49346)
71061 (A49346)
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
