PEX preferences
   / PEX preferences
Good information. The price of the Nibco crimper will kill the deal for many of us interested in doing some rework of our plumbing and not using it as a full time profession. Wirsbo has some decent considerably cheaper expanders unless you go with the battery operated type. I also agree that getting PEX to look decent when installed is a trick and rarely ever better looking than copper. If the Nibco PEX is better, could one buy their tubing and use a different clamping system? I suspect ID and OD are identical. I am going to give the SharkBite crimpless a shot for an outdoor fountain. I have SharkBite tubing. SharkBite also has a crimp system with SS crimps and what appears to be quite thick brass fittings. PEX has been popular with new homes here in my area especially with folks on wells that have slightly to well above normal acidic water. Even type L cannot withstand acidic water for more than about 20 years before its gone. I understand PEX has been used in Europe for at least 10 years longer than here in the US. The pipe itself at this point seems pretty much impervious to everything but rodents and UV. Who knows though, PE had major issues after much was used in homes.
I am a plumber in Illinois. I researched PEX for over a year before I started using it. The Zurn issue was the yellow brass fittings and the wall thickness. The yellow brass dezincafied and then broke where it was thin. Wirsbro system uses the expander system. I use Nibco PEX and Veiga Red Brass fittings and SS crimp sleeves. Sleeves are longer and make a fitting that looks like a hydraulic fitting. There are several methods of making PEX. The Nibco system has the best memory, can stay in the sun longer, tends to stay straight when straightened, and you can get it in " ridgid" straight 20' lengths. In Illinois we have to up size when using insert fittings. That makes us use 1 1/4" for 1" copper. The down side is the tool to crimp it is $1600. As far as Sharkbite fittings, be very careful. I know a plumber that did a home in them and had so many leaks he didn't make a nickle on the job. They are great for repairs but they are iffy when the pipe gets in a bind. I tell my customers that copper and PEX have good and bad qualitys. It is pretty much even except the PEX is cheaper but the copper looks much better. As far as smaller lines, like I said in Illinois it isn't possible. I still use copper to run in the walls down through the floor then connect to PEX for the long runs. It is much nicer making connections to the faucets from copper. Also we have to put air chambers on the fixtures and PEX does't work well for that.
   / PEX preferences #12
As long as you use the 1" or smaller the hand crimpers will work with the Nibco system. If you have acidic water, they offer a plastic fitting that is supposed to be tough as nails. I haven't used them. The Nibco pipe can use other brand fittings. The fittings can be used with other rings also. I just prefer SS and the larger surface area of the crimp. The info I got about PEX, when I researched it, was that it had been in Europe for 40 years. They had done demo on older buildings and took samples of the first PEX . It was ran through the test lab and passed all the tests that new PEX can. 40 year old copper wouldn't even come close to doing that.
   / PEX preferences #13
I insulated the hot water and used bulk plastic clips for support that came with the system. I looked a lot at the sharkbite stuff and would use it for repair or maybe additions but I would not use it for an entire system.
   / PEX preferences #14
We are running 3/4 pex out to a new 64x40 pole building in progress. I have also used it in my house.
   / PEX preferences
Do you have to run it in a chase or can you do direct burial? I would think using something like electrical conduit with the sweeps would work well. For 3/4" I'm thinking 1 1/4" to 1 1/2" conduit.
   / PEX preferences #16
Just built a house and used wirsbo throught.... It is a tough product... Actually had a line freeze during the building process and blew the pressure cap off of the shower faucet... When fixing it you could hear the ice in the line... No leaks once thawed... Plumber said he put the same wirsbo in a house and had all the lines freeze during an icestorm... He said they were frozen solid and buldging in spots. A kerosene heater was used to thaw the lines and there were no leaks... I've been impressed so far with the research I have done or else I would t have used it in my house.
   / PEX preferences #17
I love pex. We use rehau here in addition to wirsbo. The ever-lock system uses a metal collar in place of the plastic one, just like hydraulic hoses, and it is strong!
At a sales seminar one guy asked how strong it was and got no answer, until an old coot in the back said he wrapped it around a bumper and pulled a dead F350 crew cab home with a blown tranny, tuff stuff
The shark bites are not legal for use in walls here, they must be accesable. And i have seen several failures. We use them for temp hook ups all the time
   / PEX preferences #18
I use shark bites a lot on boiler systems when it is useful to have a fitting that lets the pipe turn. I have had zero problems with them. Otherwise, i use crimp rings (the style without the ears).
Ken
   / PEX preferences #19
Don't know what your code requires. Around here you can direct bury. If you use this product. I would suggest install a tracer wire . You'll be able to locate the line if you need to in the future
   / PEX preferences #20
I have pulled a broken line under a footing through the backfill by a Viega coupling using the SS long sleeves. Not really broken, it was ran over by a skid loader and then he turned a 360 on top if it. I cut it out, but the line wasn't cut. I had one of the ss rings that use the ears break. I have not used any since.
2015 WESTERN STAR 4900EX (INOPERABLE) (A58214)
2015 WESTERN STAR...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2014 Chevrolet Impala LT Sedan (A56859)
2014 Chevrolet...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
2015 MACK CXU613 (A58214)
2015 MACK CXU613...
