Mowing PTO 540?
/ PTO 540? #1
birdbert
New Holland TC25
Question on TC25D: What engine rpm gives 540 on the PTO? Birdbert
/ PTO 540? #2
I can't answer exactly, but there should be a mark or symbol on the tachometer that indicates the required engine RPM to achieve 540 PTO RPM. My "guess" would be around 2500 or so.
/ PTO 540? #3
2464 RPM's
/ PTO 540? #5
I know while shredding last night I hit about 2800rpm a few times and I'm still here. I thought it may open up a space/time wormhole; but it worked fine. I would not run it faster than 540 for long; but I'm guessing its not going to hurt if you hit faster every now and then.
/ PTO 540? #6
Running it real fast may hold it to the ground on hills better:laughing:
There is a poster on here who runs his at 600 with no problems.
/ PTO 540? #7
2800 engine is about 613 pto rpm.
I normally don't mind running things like mowers up to 600 rpm etc.. ( about 2737 on yer tach.. :) )
soundguy
/ PTO 540? #8
On my TC-40, the tach has two gradient marks for 640 PTO. One at 2400 rpm for a geared transmission and the other at 2500 rpm for the HST transmission. Not saying that these rpms will match your TC-25D but aren't there similar markings on your tach?
/ PTO 540?
There are no marks on this TC25D tachometer or the cover. I looked there first.
Thanks for the tips to run the SQ 480 gear box at around 2500 on the engine tach.
Birdbert
/ PTO 540? #10
You should have an operator's manual for this tractor...I suggest you read it. As Kenny wrote, there should be a mark at PTO speed. It may not be obvious, just an extended RPM speed mark, for example.
If all else fails, call your local CNH dealer.
2019 Ford F-550 4x4 Service Truck (A61573)
2019 Ford F-550...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
66in Bucket Skid Steer Attachment (A61572)
66in Bucket Skid...
2015 Dodge Journey SXT SUV (A61574)
2015 Dodge Journey...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
