Mowing PTO 540?
   / PTO 540? #1
birdbert
New Holland TC25
Question on TC25D: What engine rpm gives 540 on the PTO? Birdbert
   / PTO 540? #2
I can't answer exactly, but there should be a mark or symbol on the tachometer that indicates the required engine RPM to achieve 540 PTO RPM. My "guess" would be around 2500 or so.
   / PTO 540? #3
2464 RPM's
   / PTO 540? #5
I know while shredding last night I hit about 2800rpm a few times and I'm still here. I thought it may open up a space/time wormhole; but it worked fine. I would not run it faster than 540 for long; but I'm guessing its not going to hurt if you hit faster every now and then.
   / PTO 540? #6
Running it real fast may hold it to the ground on hills better:laughing:
There is a poster on here who runs his at 600 with no problems.
   / PTO 540? #7
2800 engine is about 613 pto rpm.
I normally don't mind running things like mowers up to 600 rpm etc.. ( about 2737 on yer tach.. :) )
soundguy
   / PTO 540? #8
On my TC-40, the tach has two gradient marks for 640 PTO. One at 2400 rpm for a geared transmission and the other at 2500 rpm for the HST transmission. Not saying that these rpms will match your TC-25D but aren't there similar markings on your tach?
   / PTO 540?
There are no marks on this TC25D tachometer or the cover. I looked there first.
Thanks for the tips to run the SQ 480 gear box at around 2500 on the engine tach.
Birdbert
   / PTO 540? #10
You should have an operator's manual for this tractor...I suggest you read it. As Kenny wrote, there should be a mark at PTO speed. It may not be obvious, just an extended RPM speed mark, for example.
If all else fails, call your local CNH dealer.
We do NOT accept credit cards as payment. (A50120)
We do NOT accept...
198367 (A51243)
198367 (A51243)
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
2016 FREIGHTLINER CASCADIA DAY CAB (A52141)
2016 FREIGHTLINER...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
