Looking for a Middlebuster/Subsoiler combo
   / Looking for a Middlebuster/Subsoiler combo #1
Alpocat
Member
I'm in the market for a middlebuster and subsoiler. I like the idea of the combo unit and I've seen several that may do the job for me. Of course, I'm looking for the best unit for the job. Most of the work would be on Food Plots in Georgia red clay. Digging ditches, laying wire and pipe are certainly not out of the question.
I really like this one from LMC (Lowery manufacturing).
I like the fact that it's a trailer mover as well. It also looks like it would shear without damaging the plow. Does anyone have one? What's the price?
I also ran across this one from Northern Tool under the Nortrac Name. Does anyone know who makes it? This isn't a combo tool, but it's adjustable and the shear point looks right to me. I wonder if you can buy the subsoiler tool point?? I worry that theres no gusset where the two pieces of tubing join.
What do you guys think?
   / Looking for a Middlebuster/Subsoiler combo #2
TSC sells/has sold variations on the one pictured on the bottom. That is where lots of us got ours for something like $140. For what we use it for? It's perfectly suited and a bargain.
The top photo obviously represents a higher class unit and the price will reflect that. It isn't unusual to find any implement built/priced at low, medium, to pro line.
Ya pays yer money and ya takes yer choice.
I called the closest Northern Tool and asked them about their middlebuster. Apparently, this is the same one offered by Gearmore and Rankin out west. Northern didn't have one in stock, but they seemed to be willing to get one shipped to the store at no cost to me. They don't offer a subsoiler bit like Gearmore and Rankin. Does anyone know the hole spacing of the subsoiler bit? I'm just wondering if I can order one from Agri-Supply or maybe Gearmore or Rankin.
Now that I think about it. Maybe I could buy the Subsoiler and buy the furrow blade. Does anyone know the correct one?
   / Looking for a Middlebuster/Subsoiler combo #4
The bit spacing on my Rankin is 2 1/4"- I'd be interested in a plow spade that fit as well.
   / Looking for a Middlebuster/Subsoiler combo #6
If it's 2-1/4", I bet this would work!!
FURROWER 16 X 4.75MM - Agri Supply
Now to find the subsoiler point. Can anyone help?
I use that very same blade for a potato plow on this subsoiler:
It works okay bolted directly to the subsoiler, but the angle is a little shallow. The last time I used it I tried putting a 3/4" stack of washers between the aft bolt holes, between the plow and frame, to give it a steeper angle. This worked much better. It worked so well that I plan to make a wedge shaped adapter for future plow work.
I still need to make a "fuzed" top link pin so it will shear out before I rip something off the back of my tractor (or wind up riding the hood) next time I hit a big root. It stops in a real hurry.
-Jim
I called Agri-Supply about the one below, but the lady I spoke to didn't know much. She couldn't even tell me the bolt hole centers. This one looks very similar to the Northern tool Middle Buster blade.
FURROWER 12 X 4.75 MM - Agri Supply
I spoke to a guy at Rankin and he said the furrower was a 12", but he quoted me a price of $30.
I wish someone knew for sure that it would fit. Even if it didn't, I bet I could come up with an adapter.
   / Looking for a Middlebuster/Subsoiler combo #8
As mentioned the cutting angle of the middlebuster, and subsoiler sold at TSC, etc. are different as are the depths they are capable of working. The subsoiler will go much deeper, but it looks like you would need a fair sized tractor to lift it out of the ground. If I remember right the pins were darn near 25" high from the cutting tip.
   / Looking for a Middlebuster/Subsoiler combo #9
I like walking the "yard" at Agri-supply... "found" this potato plow for $95(+/-?) thought it was a good price... the same item came as a subsoiler (thought it was the same angle but not 100% sure) - It's NOT listed online... it's adjustable (main bar can drop an extra 6" (+/-)). I went back and they were out of these but actually had more subsoilers... I need to see if I can buy (or get built) just the chisel part... I think the holes were around 2" apart. Item#73411, call your local Agri-Supply and see if they have one???
   / Looking for a Middlebuster/Subsoiler combo #10
(in my best Ed McMann voice) Sir, yes, you are correct, yes!
I had to pin the top link to the bottom hole on the transmission bracket and shorten the top link to get enough ground/blade clearance to drive across our field without pulling up divots.
-Jim
Hey teg,
Would you mind measuring the bolt hole center to center of the furrower on your middlebuster?
   / Looking for a Middlebuster/Subsoiler combo #12
Hey teg,
Will do but it will be next wk/ed (the 20th) :eek: before I'll visit my tractor again (sorry to say) Although, that would be a very good excuse to visit Agri-Supply!!! Been wanting to see if they sell the chisel part...
Thanks a bunch. I'd like to know if they sell the chisel point too.
Sadly, the most local Agri-Supply is 232 miles away.
   / Looking for a Middlebuster/Subsoiler combo #14
They had one left of the red adjustable one (like the middle buster photos in my post above). Then they had a King Kutter, yellow subsoiler. Then a black Middle buster. The inventory # are seen and you can look them up (EXCEPT for the red one, this one was listed instore only, for less then $100). They didn't have just the chisel point for the red one so I hope to modify one of the others to fit... Few photos of the other chisel points (poor lighting).
PS. Thanks for "making" me go to Agri-Supply... I had forgotten I needed a 3"x24" hydraulic ram for my log splitter... :confused2:
   / Looking for a Middlebuster/Subsoiler combo #15
I was just going to sandwich a couple layers of the 1/8" steel strip they have at TSC, etc. to make a chisel point for mine, but I haven't gotten to it yet.
Thanks teg! I certainly appreciate it. Let me know what you come up with adapting the subsoiler bit. The #15485 looks promising.
I called Agri-Supply this morning and they found a few of the Middlebusters and Subsoilers in their stores. Shipping costs made it prohibitive. :(
I think I'm going to call Northern and order the Middlebuster and then take a drive later in the week to TSC to see what I can dig up to use as a subsoiler bit.
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
Towable T/A Flammable Liquid Transport Tank (A59228)
Towable T/A...
