Traction farmtrac 535 traction
/ farmtrac 535 traction #1
plumbpaul
kenner,louisiana
farmtrac 535
buying a disc harrow dealer recommends i fill tires is this something i can do by gettig mixture and filling through valvestems on back tube tires or let a pro do it. thanks.disc harrow weights around 650 lbs.
/ farmtrac 535 traction #2
any tractor dealership should be able to do it for you. i would strongly reccomend against you doing it yourself. most people don't have the right equipment for such a job, and without the right equipment and/or experience you can get seriously inured or even killed. a filled tractor tire ain't a light thing by no means! some places have a mobile service and can come to where you are and do it at your home/farm. check around at some local tire shops too. you'll see a big difference when pulling your new disk with the tires filled.
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
POWER TECH GENERATOR (A63569)
POWER TECH...
Kubota L2501 (A62177)
KING 4R CHISEL RIPPER BEDDER (A63291)
KING 4R CHISEL...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
