Traction farmtrac 535 traction
   / farmtrac 535 traction #1
plumbpaul
kenner,louisiana
farmtrac 535
buying a disc harrow dealer recommends i fill tires is this something i can do by gettig mixture and filling through valvestems on back tube tires or let a pro do it. thanks.disc harrow weights around 650 lbs.
   / farmtrac 535 traction #2
any tractor dealership should be able to do it for you. i would strongly reccomend against you doing it yourself. most people don't have the right equipment for such a job, and without the right equipment and/or experience you can get seriously inured or even killed. a filled tractor tire ain't a light thing by no means! some places have a mobile service and can come to where you are and do it at your home/farm. check around at some local tire shops too. you'll see a big difference when pulling your new disk with the tires filled.
Honda UTV (A56859)
Honda UTV (A56859)
2016 Kia Optima Sedan (A56859)
2016 Kia Optima...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A58375)
UNUSED CFG...
IRanch High-End Mini Golf Cart (A57149)
IRanch High-End...
SKID STEER ATTACHMENT BRUSH WITH BOX (A58216)
SKID STEER...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
