Oil & Fuel 3032e stalls after it's warm
/ 3032e stalls after it's warm #1
scgamecock
jd3032e
My tractor has started stalling after it get's warm. Cold it runs good for about 1 to 2 hours. It always restarts and will run for a short while before doing it again. I changed fuel and both air filters. Has to be something silly; thanks for any help
next question on my tractor. The fuel going to the pre filter, what type of flow should be there. Isn't that gravity and should be quick?
/ 3032e stalls after it's warm #4
Make certain the vent in the fuel cap is not plugged. Try running with the cap loose a bit to see if it still stalls.
Just to let you know, I found the problem. Inside the fuel tank is a strainer and mine was plugged. Still need to take the tank off at sometime, thanks for the help
/ 3032e stalls after it's warm #6
I would think that is a very new tractor to have tank problems. Any idea what caused this?
What are you using to fill the tractor?
/ 3032e stalls after it's warm #7
I have a similar issue with my 3032e, still trying to solve it..
How did you get the strainer out? Perhaps I have the same problem!
Thanks,
BN
/ 3032e stalls after it's warm #8
This was it!
Thanks SCGamecock!
BTW, the screen was completely caked with black slime preventing fueld from passing through to drain the tank.
Good call...
