Oil & Fuel 3032e stalls after it's warm
/ 3032e stalls after it's warm #1
scgamecock
jd3032e
My tractor has started stalling after it get's warm. Cold it runs good for about 1 to 2 hours. It always restarts and will run for a short while before doing it again. I changed fuel and both air filters. Has to be something silly; thanks for any help
next question on my tractor. The fuel going to the pre filter, what type of flow should be there. Isn't that gravity and should be quick?
/ 3032e stalls after it's warm #4
Make certain the vent in the fuel cap is not plugged. Try running with the cap loose a bit to see if it still stalls.
Just to let you know, I found the problem. Inside the fuel tank is a strainer and mine was plugged. Still need to take the tank off at sometime, thanks for the help
/ 3032e stalls after it's warm #6
I would think that is a very new tractor to have tank problems. Any idea what caused this?
What are you using to fill the tractor?
/ 3032e stalls after it's warm #7
I have a similar issue with my 3032e, still trying to solve it..
How did you get the strainer out? Perhaps I have the same problem!
Thanks,
BN
/ 3032e stalls after it's warm #8
This was it!
Thanks SCGamecock!
BTW, the screen was completely caked with black slime preventing fueld from passing through to drain the tank.
Good call...
UNUSED KJ K2010 HD CHICKEN COOP (A62131)
UNUSED KJ K2010 HD...
HOMEMADE 52"X12' S/A TRAILER (A62130)
HOMEMADE 52"X12'...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A62131)
UNUSED WOLVERINE...
2018 INTERNATIONAL LT625 T/A MID ROOF TRUCK TRACTOR (A59909)
2018 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED PEANUT WAGON QUICK HITCH (A62131)
UNUSED PEANUT...
