Oil & Fuel 3032e stalls after it's warm
   / 3032e stalls after it's warm #1
scgamecock
jd3032e
My tractor has started stalling after it get's warm. Cold it runs good for about 1 to 2 hours. It always restarts and will run for a short while before doing it again. I changed fuel and both air filters. Has to be something silly; thanks for any help
next question on my tractor. The fuel going to the pre filter, what type of flow should be there. Isn't that gravity and should be quick?
   / 3032e stalls after it's warm #3
Yes, it should flow at a pretty good rate unless obstructed.
Possible you just answered your first question with your second question. :laughing:
Welcome to TBN ;)
   / 3032e stalls after it's warm #4
Make certain the vent in the fuel cap is not plugged. Try running with the cap loose a bit to see if it still stalls.
Just to let you know, I found the problem. Inside the fuel tank is a strainer and mine was plugged. Still need to take the tank off at sometime, thanks for the help
   / 3032e stalls after it's warm #6
I would think that is a very new tractor to have tank problems. Any idea what caused this?
What are you using to fill the tractor?
   / 3032e stalls after it's warm #7
I have a similar issue with my 3032e, still trying to solve it..
How did you get the strainer out? Perhaps I have the same problem!
Thanks,
BN
   / 3032e stalls after it's warm #8
This was it!
Thanks SCGamecock!
BTW, the screen was completely caked with black slime preventing fueld from passing through to drain the tank.
Good call...
Husqarvana 46in Riding Mower (A56859)
Husqarvana 46in...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
Black Steel Diamond Plate (A55758)
Black Steel...
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A55973)
2019 John Deere...
2018 Chevrolet Tahoe SUV (A55973)
2018 Chevrolet...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
