Replacing trailer deck...with what?
/ Replacing trailer deck...with what? #1
97exc
Have a 5 x 10 utility trailer, existing 2 x 6 wood deck is splitting badly. I think its old pressure-treated lumber, not totally sure. Anyway, I took it all out to paint the trailer and now would be a good time to replace it with new. I live in Colorado, the trailer stays outside most of the time, sometimes tarped. Its used to haul lawn equipment, ATV, snowmobile, etc the majority of the time. I have loaded it down with organic materials and will probably haul some sod and rock at times.
Based on these uses, what do you suggest as far as replacement decking?
/ Replacing trailer deck...with what? #2
I just re did my 5 x 8 trailer I use for hauling around a riding mower. (actually 5'4" x 8' deck). It uses 5/8" marine grade plywood for a deck. That's more than enough for hauling small stuff. On mine, two sheets of plywood were cut 32" wide, laid in the frame and bolted with carriage bolts.
/ Replacing trailer deck...with what? #4
i'd go back with 2x6 pt, then paint it with black asphalt paint. should last a looong time.
if you moved heavy stuff.. I'd lay a sheet of 3/4" marine plywood in it and screw down after painting both sides and the deck.
really spreads the weight around.
soundguy
/ Replacing trailer deck...with what? #5
i've used 5/8" plywood (was free) on a snowmobile trailer i built where the supports were 2' apart, but eventually it sagged between the supports. guess that's why the ones you buy all seem to use 3/4". i'm going to build a 5~ish x 10' utility trailer soon, and i've been planning on using 5/4 pt decking. it's pretty strong for anything i would be putting on the trailer, though it's probably not any cheaper than actually using 2x6 pt as has been suggested.
/ Replacing trailer deck...with what? #6
I would go back with PT lumber also.
Chris
/ Replacing trailer deck...with what? #8
I agree with 2x6 or 2x8 treated lumber.
It may well be that what you had originally was not treated. I know many of the builders skimp and don't use treated lumber. :confused:
I've replaced decks on two trailers like yours in the past few years.
/ Replacing trailer deck...with what? #9
Many of the newer utilities are showing up with Trex. The artificial boards would be quite expensive. They don't seem to be any lighter in weight either. Just sayin'.
/ Replacing trailer deck...with what? #10
Wouldn't rough cut hemlock be far cheaper, stronger and durable than PT? PT is brittle stuff and cracks, splinters, easily.
/ Replacing trailer deck...with what? #11
The PT around here is southern yellow pine ("SYP"), a soft wood. I've never seen it "brittle" or cracking.
I can get 1" hemlock barn siding, but I've never seen 2" around here.
/ Replacing trailer deck...with what? #12
I would go with treated lumber & coat it with a water repellent once a year (after it dries). I've done this on my 16' & it's lasted for many years! ~~ grnspot110
/ Replacing trailer deck...with what? #13
Top quality builders around here use rough saw oak for trailer decks. We have a local saw mill and can get it but its quite expensive. Its not something you can find at Lowes or Home Depot. For the majority of us PT lumber from a box store will do the job for 15 years or so if taken care of.
Chris
/ Replacing trailer deck...with what? #14
White oak or red oak? White is supposed to be more rot resistant. It would be excellent for a trailer, if you can find it.
Ken
/ Replacing trailer deck...with what? #15
It is SYP here to and strikes me in no way as being as durable when it comes to anything other than being walked on. Anyone who saws lumber can get you the 2". It also will provide better traction.
In the case of a trailer deck, it too will last for years because it doesn't stay wet.
But, it's your trailer!
/ Replacing trailer deck...with what? #16
I know 2" rough swan white oak is popular for trailer decks.
But if you dont have any band mills near buy that can supply it.... 2x treated from a box store should last another 10-15 years or more
/ Replacing trailer deck...with what? #17
Ken
I am not sure. I am pretty sure it was white though. I know one guy who used it and it was twice as much as PT lumber.
Chris
/ Replacing trailer deck...with what? #18
If it is just a 5x10, I use the marine plywood. That will be expensive enough. There is no sense in getting carried away, unless your going to put an excavator on it.
I hold it down with urethane construction adhesive, and a few screws on the ends.
A light annual coat, of SW Deckscapes, oil based waterproofing toner, and it should be serviceable for a long time.
If you have areas your concerned about spanning with plywood, add some supports.
/ Replacing trailer deck...with what? #19
I'd love to have White Oak for a trailer floor...the WO has closed pores where the red oak is open..that is why WO was prized for shipbuilding.
But PT SYP has served me well for many years..the deck I built with it on my house has been holding up for over 25 years. Never had a thing done to it.
Seems to me the artificial deck wood has little strength necessitating a whole lot more support under it.
/ Replacing trailer deck...with what? #20
They use presure treated 2x pine, from the factory. I'd buy #2 grade or better.
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
2014 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A65056)
2014 CATERPILLAR...
2018 Manitou MLT960 ST4 S2 13,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
2021 Tufline BCP2416 8ft. Cultipacker Tractor Attachment (A66734)
2021 Tufline...
