Self made attachments
/ Self made attachments #31
Although I have extremely modified my 6 foot king cutter tandem disk to fit my needs , not really home built .
Am working on what used to be a single gang pull disk that we originally converted to a 3 point lift ( but with addition of k.k. disk is no longer needed ) , but now have saved our 3 point frame , part of the original disk frame and am converting / adding a 4" x 4" 6' steel tubing with slots both top and bottom to accept 17"+ scarifier shanks similar to this one :
SCARIFIER SHANK 17.88'' 4 HOLE - Agri Supply
15 slots but will only pull 8 shanks or 7 depending on which slots I use .
It would be similar to a box blade , but with-out the box as I already have a blade , so not looking for another .
Fred H.
/ Self made attachments #32
Is this how mahindra actually advertizes?? or is this guy just doing it on his own cause he's nuts???
Well if you can't get your 15-minutes of fame on Letterman by chasing bin Laden, this is the next best way I guess.
I liked the redhead "wife" but wondered how that guy managed to land her. :ashamed::ashamed:
Redhead wife was an actress portrayal and she was compensated for appearing in the video.
/ Self made attachments #33
My implements are all "home made" except the tiller. But the thing that I use the most is the Quick Hitch. The QH makes changing implements so much easier that I find I change implements to do just quick 2 minute jobs.
Probably my imitation Gannon rollover box has the highest notoriety, but I use the scoop and the rear blade more. I bent the frame of the RB on a curb pushing snow this past winter and need to make version 2.
Mike
/ Self made attachments #34
Larry I just re-watched all of your awesome videos. It was a real pleasure to see your first class projects in one place. :thumbsup:
When I remake my RB I am thinking of incorporating some of your design ideas in the rake (parallelogram side shift), without the hydraulics, unfortunately. :(
Mike
/ Self made attachments #35
I've enjoyed reading all the post and seeing all the pics here. I must say, Larry, those vids are impessive. I've always enjoyed your threads and projects. :thumbsup:
/ Self made attachments #36
Does it count as an attachment? On my previous tractor, I built my own TnT setup.
It is not in the budget right now for the new used tracot. And, it is what I miss the most.
I did add a reinforced tab on my scraper box, which has a 2" ball mounted. It works great for moving trailers. Since I almost always have the box scraper on the tractor, it works out well. I could use the drawbar, but then I have to drop the scraper.
/ Self made attachments #37
DON'T TRY THIS AT HOME ;-) Me and a buddy welded some special lifting forks for the front and rear end of my Mahindra 3535. Why? Cuz of a bet. I bet my neighbors my Mahindra could lift their John Deere and Kubota tractors. Check out my custom forks in action in my YouTube video. Needless to say, I won the bet...YouTube - Man Lifts Tractor
I believe that's about the biggest waste of electrons I've ever seen, even on the web.
/ Self made attachments #38
Here's a quick question, what is a good lenght for a boom pole, I am gonna start gathering some material to build one but jut need an idea lenght wise..
thx
/ Self made attachments #39
thx
Depends on the tractor size, the bucket (assuming that's where you intend to mount it), etc; but I would guess 8' max.
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
KJ K2825 28'x25' Metal Workshop (A60463)
KJ K2825 28'x25'...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2021 CATERPILLAR 302.7DCR EXCAVATOR (A62129)
2021 CATERPILLAR...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
