Self made attachments
/ Self made attachments #21
I have made lots of attachments but the most used would definately be the 3ph reciever hitch. I am forever building something that slides in the hitch and works off from that. I have 2 factory boom poles but I built a small one out of 2" tubing to work off of the reciever. Sometimes I need the factory one but usually the smaller one in the reese hitch gets the job done and is a lot easier to change out.
Whenever I take an implement off of a tractor I put the reciever tube back on. Keeps the sway out of the lift arms and is always ready to move a trailer. Built 3 of them, have 2 tractors. If someone needs to use one of my home built reciever attachments, I have an extra hitch to let them use also.
/ Self made attachments #22
My most used is the front quick-hitch (either with, or without my three-point hitch mounted). With it, I can put any three-point attachment on the front, including my carryall. Coolest so far is my boom pole (in my humble opinion).
really interesting. have close up pictures of your build?
/ Self made attachments #23
"really interesting. have close up pictures of your build? " Here are a couple of pics. You can see more if you search under boom pole and quick hitch, etc.
/ Self made attachments #24
DON'T TRY THIS AT HOME ;-) Me and a buddy welded some special lifting forks for the front and rear end of my Mahindra 3535. Why? Cuz of a bet. I bet my neighbors my Mahindra could lift their John Deere and Kubota tractors. Check out my custom forks in action in my YouTube video. Needless to say, I won the bet...YouTube - Man Lifts Tractor
That may be impressive to some people but IMO it doesn't make a mahindra better than the JD or Kubota there.
A 4200lb tractor being able to lift a 2600lb bota and a 2900lb john deere that are a size class smaller isn't that impressive to me.
I'm mean no disrespect to mahindra and they make a great tractor, but step up to a 4200lb tractor of any make and most will be able to do that.
HP is not a good way to size tractor classes. Mahindra tends to put smaller motors in larger framed tractors to be on top of the specs board and others put larger HP engines in smaller tractors.
Dont take this the wrong way. It does look impressive, until you look at the #'s. But what WAS impressive was being able to design and build them forks for that show. That had to take some planning and know how cause you probabally would have lost the bet if the forks broke and you dropped one of them tractors.
So...How many cases of beer did you win:D
/ Self made attachments #25
I liked everthing except the acting in your Mahindra AD. special stabilization and specially prepared tractor ( in the credits) come on.
/ Self made attachments #27
"Professional operators with controlled conditions and specialized stabilizing equipment were used in this video..."
And you'll notice tractorguy101 has 6 posts. All yesterday and all inserting this marketing video. That type of marketing turns me off.
/ Self made attachments #28
I guess I didn't realize that until you mentioned it. All 6 posts within 45min. Just reading them under his profile reminds me of them spam e-mails I get everyonce in awhile from c-list, about refering you to some NY times artical about how to get rich quick yada yada.
Is this how mahindra actually advertizes?? or is this guy just doing it on his own cause he's nuts???
/ Self made attachments #29
I liked the redhead "wife" but wondered how that guy managed to land her. :ashamed::ashamed:
I was not sure if the two neighbours were depriving two villages somewhere of their idiots or as you say just bad actors from a Ronco or K -tel ad:thumbsup:
/ Self made attachments #30
Just a small sample of my home made all time favorites. First 5 videos are my Robo Rake made completely from scratch. (Click on image to watch the videos.)
Robo Blade with gearbox built by 3RRL:
Home Made Grapple:
Home Made Dump Trailer with two stage tailgate:
Larry
/ Self made attachments #31
Although I have extremely modified my 6 foot king cutter tandem disk to fit my needs , not really home built .
Am working on what used to be a single gang pull disk that we originally converted to a 3 point lift ( but with addition of k.k. disk is no longer needed ) , but now have saved our 3 point frame , part of the original disk frame and am converting / adding a 4" x 4" 6' steel tubing with slots both top and bottom to accept 17"+ scarifier shanks similar to this one :
SCARIFIER SHANK 17.88'' 4 HOLE - Agri Supply
15 slots but will only pull 8 shanks or 7 depending on which slots I use .
It would be similar to a box blade , but with-out the box as I already have a blade , so not looking for another .
Fred H.
/ Self made attachments #32
Well if you can't get your 15-minutes of fame on Letterman by chasing bin Laden, this is the next best way I guess.
Redhead wife was an actress portrayal and she was compensated for appearing in the video.
/ Self made attachments #33
My implements are all "home made" except the tiller. But the thing that I use the most is the Quick Hitch. The QH makes changing implements so much easier that I find I change implements to do just quick 2 minute jobs.
Probably my imitation Gannon rollover box has the highest notoriety, but I use the scoop and the rear blade more. I bent the frame of the RB on a curb pushing snow this past winter and need to make version 2.
Mike
/ Self made attachments #34
Larry I just re-watched all of your awesome videos. It was a real pleasure to see your first class projects in one place. :thumbsup:
When I remake my RB I am thinking of incorporating some of your design ideas in the rake (parallelogram side shift), without the hydraulics, unfortunately. :(
Mike
/ Self made attachments #35
I've enjoyed reading all the post and seeing all the pics here. I must say, Larry, those vids are impessive. I've always enjoyed your threads and projects. :thumbsup:
/ Self made attachments #36
Does it count as an attachment? On my previous tractor, I built my own TnT setup.
It is not in the budget right now for the new used tracot. And, it is what I miss the most.
I did add a reinforced tab on my scraper box, which has a 2" ball mounted. It works great for moving trailers. Since I almost always have the box scraper on the tractor, it works out well. I could use the drawbar, but then I have to drop the scraper.
/ Self made attachments #37
I believe that's about the biggest waste of electrons I've ever seen, even on the web.
/ Self made attachments #38
Here's a quick question, what is a good lenght for a boom pole, I am gonna start gathering some material to build one but jut need an idea lenght wise..
thx
/ Self made attachments #39
thx
Depends on the tractor size, the bucket (assuming that's where you intend to mount it), etc; but I would guess 8' max.
