Buying Advice TC30 to replace old 2000
/ TC30 to replace old 2000 #1
Swampster
My old Ford 2000 (about 1964) does a decent job with a 6 foot King Kutter bush hog. Bogs down sometimes in very thick material or mowing lots of brush/trees. Can I expect at least equal performance with the TC30? It is a used 2002 model.
/ TC30 to replace old 2000 #2
I have a 2000 tC-29D that I have owned since new and I routinely bush hog 3 foot tall grass and brush and have had no problems. It has lots of power.
/ TC30 to replace old 2000 #3
You really need to compare PTO HP of your old Ford to the NH TC-30. IIRC, the TC-30 gear puts out about 23-25 PTO HP.
/ TC30 to replace old 2000 #5
You might want to look for around 40 or 45 pto hp . A used ford 3910 or 3930 has around 45 pto hp . It will run a 6 ft cutter real nice and do better on fuel than your 2000 ( unless you have a diesel engine in it ) .
/ TC30 to replace old 2000 #6
the old 2000, if a gasser could be a 134ci or 144ci diesel.. or if a later model 158ci ,my units with the 134ci, I would say put out close to 32 pto hp... I have used a 6' cutter on my 134ci engines.. and they seem to do fine with it in most areas. I can mow weeds that are taller than me with an older 8n and a 5' mower ( 27 pto hp )
soundguy
EAGER BEAVER SRH150W ASPHALT ROLLER (A63290)
EAGER BEAVER...
Mini rock grapples (A61567)
Mini rock grapples...
Informational Lot - Financing (A63688)
Informational Lot...
Willmar 4550 Wrangler Articulating Loader (A63118)
Willmar 4550...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
