Is it a SCUT or a CUT?
   / Is it a SCUT or a CUT? #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T62, MT55, E42R, E10, John Deere 4100
After some thought, I wondered what category my yanmar would be in. A SCUT or a CUT? What do you think? I've parked it next to my Grandpa's and neighbor's SCUTs for a size comparison. Yet it also is around the same size as my neighbor's old 4100.
   / Is it a SCUT or a CUT? #2
The poor Deere, she needs a bath.
Is the category really important? Or are you trying to win a bet? :D
It is just out of curiosity.
   / Is it a SCUT or a CUT? #4
I don't think it is a CUT, how about calling it a SCUT on steroides?
   / Is it a SCUT or a CUT? #6
Does it have a full CAT1 3PH? If yes then it is a CUT in my opinion. The tractors with a "Limited" 3PH are usually considered SCUT's.
   / Is it a SCUT or a CUT? #7
My MF gc2400 has a full cat. 1 hitch. The New Hollands also have the full cat 1 hitch. I believe both are SCUTS.
Still not sure why they put limited cat. 1 on JD, Kubota and Cub/Yanmar.
Don
   / Is it a SCUT or a CUT? #8
That's as good a way to explain the difference as I can think of. I had a Kubota BX that had a limited 3 PH then I bought a slightly larger B2620 that had a full CAT1 3PH. The full CAT1 3PH was one of the reasons I the traded for the 2620. I consider the 2620 a compact tractor. In retrospect the BX was a sub compact. In my opinion the designation is actually redundant.
   / Is it a SCUT or a CUT? #9
Kennyd I never heard of "Limited" 3PH, what is it? I know what Cat 0,1,2 & 3 are. I would say SCUT has more to do with the frame and tire size. They could have Cat 0 or Cat 1 3pt, some could have high HP so HP can go into the CUT's.
   / Is it a SCUT or a CUT? #10
This opinion is not necessarily accurate or legitimate. It is just what I have rolling around in my head.
It seems that the SCUTs have a lawn mowing component in their heritage. I know they have evolved to be able to do much more than this, but the very small wheels, coupled with the belly-mower wheelbase defines a SCUT for me.
While your tractor is certainly capable of mowing activities, it was clearly not designed with this as a primary consideration. The larger tires and ground clearance suggests to me that your machine was designed with ground engaging implements in mind. So if I was forced in to the classification game, I would call your tractor a CUT.
Kenny probably has a better set of criteria than I do. :thumbsup:
2015 Haulotte 5533A (A53316)
2015 Haulotte...
UNUSED FUTURE FT-X39 39" HYD TRENCHER (A57193)
UNUSED FUTURE...
2020 CATERPILLAR 299D3 SKID STEER (A52707)
2020 CATERPILLAR...
2004 E-Z-Go ST350 Gas Utility Cart (A55851)
2004 E-Z-Go ST350...
UNUSED FUTURE CAT305 EXCAVATOR AUGER DRILL (A57193)
UNUSED FUTURE...
2004 Volvo XC90 SUV (A55853)
2004 Volvo XC90...
