Is it a SCUT or a CUT?
   / Is it a SCUT or a CUT? #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T62, MT55, E42R, E10, John Deere 4100
After some thought, I wondered what category my yanmar would be in. A SCUT or a CUT? What do you think? I've parked it next to my Grandpa's and neighbor's SCUTs for a size comparison. Yet it also is around the same size as my neighbor's old 4100.
   / Is it a SCUT or a CUT? #2
The poor Deere, she needs a bath.
Is the category really important? Or are you trying to win a bet? :D
It is just out of curiosity.
   / Is it a SCUT or a CUT? #4
I don't think it is a CUT, how about calling it a SCUT on steroides?
   / Is it a SCUT or a CUT? #6
Does it have a full CAT1 3PH? If yes then it is a CUT in my opinion. The tractors with a "Limited" 3PH are usually considered SCUT's.
   / Is it a SCUT or a CUT? #7
My MF gc2400 has a full cat. 1 hitch. The New Hollands also have the full cat 1 hitch. I believe both are SCUTS.
Still not sure why they put limited cat. 1 on JD, Kubota and Cub/Yanmar.
Don
   / Is it a SCUT or a CUT? #8
That's as good a way to explain the difference as I can think of. I had a Kubota BX that had a limited 3 PH then I bought a slightly larger B2620 that had a full CAT1 3PH. The full CAT1 3PH was one of the reasons I the traded for the 2620. I consider the 2620 a compact tractor. In retrospect the BX was a sub compact. In my opinion the designation is actually redundant.
   / Is it a SCUT or a CUT? #9
Kennyd I never heard of "Limited" 3PH, what is it? I know what Cat 0,1,2 & 3 are. I would say SCUT has more to do with the frame and tire size. They could have Cat 0 or Cat 1 3pt, some could have high HP so HP can go into the CUT's.
   / Is it a SCUT or a CUT? #10
This opinion is not necessarily accurate or legitimate. It is just what I have rolling around in my head.
It seems that the SCUTs have a lawn mowing component in their heritage. I know they have evolved to be able to do much more than this, but the very small wheels, coupled with the belly-mower wheelbase defines a SCUT for me.
While your tractor is certainly capable of mowing activities, it was clearly not designed with this as a primary consideration. The larger tires and ground clearance suggests to me that your machine was designed with ground engaging implements in mind. So if I was forced in to the classification game, I would call your tractor a CUT.
Kenny probably has a better set of criteria than I do. :thumbsup:
2006 KAWASAKI MULE 3010 DSL UTV (A57192)
2006 KAWASAKI MULE...
2023 CATERPILLAR 259D3 SKID STEER (A52707)
2023 CATERPILLAR...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2015 Chevrolet Traverse (A56859)
2015 Chevrolet...
12ft X 16ft Value Gambrel Barn (A55853)
12ft X 16ft Value...
