Is it a SCUT or a CUT?
/ Is it a SCUT or a CUT? #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T650, MT55, E42R, E10, John Deere 4410, 4200, x500
After some thought, I wondered what category my yanmar would be in. A SCUT or a CUT? What do you think? I've parked it next to my Grandpa's and neighbor's SCUTs for a size comparison. Yet it also is around the same size as my neighbor's old 4100.
/ Is it a SCUT or a CUT? #2
The poor Deere, she needs a bath.
Is the category really important? Or are you trying to win a bet? :D
It is just out of curiosity.
/ Is it a SCUT or a CUT? #4
I don't think it is a CUT, how about calling it a SCUT on steroides?
/ Is it a SCUT or a CUT? #6
Does it have a full CAT1 3PH? If yes then it is a CUT in my opinion. The tractors with a "Limited" 3PH are usually considered SCUT's.
/ Is it a SCUT or a CUT? #7
My MF gc2400 has a full cat. 1 hitch. The New Hollands also have the full cat 1 hitch. I believe both are SCUTS.
Still not sure why they put limited cat. 1 on JD, Kubota and Cub/Yanmar.
Don
/ Is it a SCUT or a CUT? #8
That's as good a way to explain the difference as I can think of. I had a Kubota BX that had a limited 3 PH then I bought a slightly larger B2620 that had a full CAT1 3PH. The full CAT1 3PH was one of the reasons I the traded for the 2620. I consider the 2620 a compact tractor. In retrospect the BX was a sub compact. In my opinion the designation is actually redundant.
/ Is it a SCUT or a CUT? #9
Kennyd I never heard of "Limited" 3PH, what is it? I know what Cat 0,1,2 & 3 are. I would say SCUT has more to do with the frame and tire size. They could have Cat 0 or Cat 1 3pt, some could have high HP so HP can go into the CUT's.
/ Is it a SCUT or a CUT? #10
This opinion is not necessarily accurate or legitimate. It is just what I have rolling around in my head.
It seems that the SCUTs have a lawn mowing component in their heritage. I know they have evolved to be able to do much more than this, but the very small wheels, coupled with the belly-mower wheelbase defines a SCUT for me.
While your tractor is certainly capable of mowing activities, it was clearly not designed with this as a primary consideration. The larger tires and ground clearance suggests to me that your machine was designed with ground engaging implements in mind. So if I was forced in to the classification game, I would call your tractor a CUT.
Kenny probably has a better set of criteria than I do. :thumbsup:
/ Is it a SCUT or a CUT? #11
The "limited" 3PH's don't lift as high, and the lower arms sometimes don't spread far enough apart to fit some implements.
Here is an example of a Woods PHD marketed to such machines: Woods PHD 25 And the King Kutter XB series stuff is also sold as "limited" 3PH compatible.
/ Is it a SCUT or a CUT? #12
Interesting thread. Wonder when anyone started worrying about it. I like old Farmalls. Had a 1941 "A" for a while. Always wanted a Cub. Or, second to that a Deere LA or AC "G".
In the 12 years I have looked at those, I have never heard reference to those being catagorzied as anything but a tractor. Pretty dang good ones too.
/ Is it a SCUT or a CUT? #13
Robert, I agree, the old iron tractors were referred to as just that, tractors. Back then they were catagoried by how many rows they could plow at one time, hence the term "one row" tractors, "two row" tractors, etc.
In todays modern smaller diesel tractors that have sometimes more horsepower than the larger built older tractors came the term CUT. But I prefer my old iron over the newer ones, just my preference, we all have them.
I too would like to find a deal on a AC "G" or a Farmall Cub, great lil cultivating tractors.
/ Is it a SCUT or a CUT? #14
Kenny I looked at your link and you sure are right. I well have to go look at one. Thanks, Lee
/ Is it a SCUT or a CUT? #15
True. And, they most old iron had Nebraska Testing, so you not only knew engine hp/tq, pto/belt hp/tq, but actual drawbar hp.
I have not idea what my old Kubota B series, or my current NH TC40, have for drawbar ratings.
/ Is it a SCUT or a CUT? #16
I agree with your opinion. SCUT's are mowers that can do some tractor stuff. CUT's are tractors that can do some mowing stuff. My Massey 1215 is definately a SCUT even though the 3PH seems to be a full Cat. 1 hitch.
/ Is it a SCUT or a CUT? #17
I agree, good definition...also think can the machine actually pull a sub soiler, plow or disk harrow and do an acceptable job...if not it is a lawn mower or if you prefer a lawn tractor..
Then what would my Simplicity 9518 be? It was used as a large riding mower. It didnt come with a MMM so I removed all of the MMM parts. Now it looks more like a tractor. Yet it is the same size as my Yanmar so does that make it a SCUT or a CUT? The 9518 is the same as the Massey 1010, Hinomoto C174, and Allis Chalmers 5015.
/ Is it a SCUT or a CUT? #19
Don
All Kubota BXs have had full Cat 1s for about 5 years (ie: BX1850, 2350, 1860, 2660, 2360, BX24, BX25 ). Still are SCUTs to me as are the MFs and NHs...
It's not HP, lift capacity, nor weight, as some of the little guys have as much or more than some of the CUTs. To me it's the size of the rear wheels. 12" wheels is a SCUT.
/ Is it a SCUT or a CUT? #20
That's how I decide the difference between a riding mower, a lawn tractor, and a garden tractor. The wheels get bigger respectively.
