bent frame on rotary mower
/ bent frame on rotary mower #1
MESSMAKER
Bluegrass,KY
DK4710SE
I am not sure when I did it as I have not done anything rough that I remember but I have twisted the A arms on the three point attachment on my King Kutter mower. They are not bent a great deal but it moves my top attachment point forward about 2". That cost me about a foot or more in lift ant the tail of the mower. I can't adjust it out with the top link. I have a shackle mount on top so I do have some room for flex. How do I repair this or can I just remove the A-arm and spin it 180 degrees so the twist is facing the tail of the mower?
/ bent frame on rotary mower #2
I see some cutters that have been heated and bent back into position and then reinforcement pieces inserted where needed and welded. You could also buy a new A-Frame from KK. Ken Sweet
/ bent frame on rotary mower #3
I’m sure every situation is different. I’ve used a come-a-long to bend mine back a couple times. Make sure it’s a heavy duty one or don’t bother. It’s no fun when something lets go.
/ bent frame on rotary mower #4
I may be misunderstanding you and this isn't always adviseable BUT this could have been caused be getting into a "dip" and the lack of play (rigid top link) may have caused it. I use a short piece of chain on my brushhog just for that reason. Just remember that by doing this it will allow the tail of the mower to lift with not much to limit it's amount of lift. I've been using a chain for years with not ill effects.
/ bent frame on rotary mower #5
My father in law was very hard on cutters, so he had his heated, bent back into place and reinforced.
/ bent frame on rotary mower #7
I don't even hook up the top link to the cutting. I just raise up the front end of the cutter when I need to and let the tail wheel hold up the back.
/ bent frame on rotary mower #8
I wouldn't want to have it so I could not pick up the rear of the deck. I put chains from the top of the A back to the rear frame. I then let the deck ride on the rear wheel and adjust the front with the 3 ph. For moving over obstacles or road travel, I lift the 3 ph high and have the chains lift the rear wheel off the ground. This keeps from putting the stress on the top arm.
/ bent frame on rotary mower #9
The KK frame is fairly easy to remove, so I'd do as you say and reverse it. That might pull the mower in too close to your rear wheels though, so be careful. I'm not sure how you would have pulled the frame forward, as any binding from backing or in the bottom of dips would push the frame towards the rear. Are you sure you have the lop hinge assembly installed properly?
/ bent frame on rotary mower #10
I think I'd get a bottle jack and chain.. or similar jack.. Ie hi lift farm jack and then start on it.. if it resists.. use a torch on it to help it bend. THEN add some angle iron supports to it to help prevent it from bending again.. either from whatever bent it the first time.. or from bending due to beaing weakend from the repair.
DO check your pto shaft length.. too long a shaft can cause binding and damage to botht he pto and mower frame.
soundguy
I think it must have been a dip,ditch or something that forced the rear of the cutter up. It seems to have swiveled on the lower arms and pivoted the shackle toward the tractor. When it ran out of movement the braces that hook on the back of the mower drove the bottom link forward. It is still somewhat of a mystery, so could be wrong.
/ bent frame on rotary mower #12
short toplink, long pto shaft and a rear obstruction could make the top of the a-frame bend towards the tractor as well.
soundguy
/ bent frame on rotary mower #13
Your story is an example of why I went with a real MD cutter (woods BB600 in my case). Other brands are similar. Buy by the total weight and that is a decent indication of the strength of the unit. The BB with chains is over 1000#. Hard for even a tractor goof like me to muck it up! Unlike the previous cutters that lasted 2-3 seasons of rocks, roots and saplings...
I would bend the parts back and weld in lots of support metal. If you don't, it will bend again and bend worse (or crack and break). That's what stressed metal does.
I think I am going to flip the mount around. I am thinking it might actually work better with a little more room for the top link. It is just about 7 bolts. Should be easy with air tools.
/ bent frame on rotary mower #15
I use a chain for top link,never would bent it if you'd had a chain on it. And if its now bent,bet you won't even notice it if you went to a chain.
/ bent frame on rotary mower #16
Jay, could you put up a picture to show us?
I have thought about a chain but I mow for other people and have to adjust the cutter to suit different needs(vacant lots, back yards or reg. pasture). The top link can keep the front from digging in when you are making a close cut.
I can't see how that would remain with a chain.
/ bent frame on rotary mower #19
many mowers have a flexible link installed at the toplink area on the mower so that it has some play.
soundguy
/ bent frame on rotary mower #20
Well,set the mower height with 3 point,basicly the only thing a top link does is lets you pick up mower and keeps mower rear from going down to low,like on a sharp hump,pto shaft might come apart in that situation,and it keeps mower from flipping or rear from raising if front hit a stump or something like that.
Chain will let you pick it up,some,chain will stop rear from going down to low,only thing a chain won't do is stop rear from raising if front hits a stup or corner of hard dirt or something like that.
I mow known ground,rough,but known and this doesn't affect me,cut with it about 5-6 inches high.
2017 Peterbilt 320 T/A Heil 28Yd Front Loader Garbage Truck (A61573)
2017 Peterbilt 320...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
John Deere 7230 (A62180)
John Deere 7230...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
