beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,693
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
I have thought about a chain but I mow for other people and have to adjust the cutter to suit different needs(vacant lots, back yards or reg. pasture). The top link can keep the front from digging in when you are making a close cut.
I can't see how that would remain with a chain.
You need to think on it some more.
A chain will do everything you want and more. The cutter height is adjusted at the leading edge with the height of the 3ph. The rear is adjusted with the setting of the rear wheel.
Right to left is adjusted with the adjustable side link on the 3ph arm.
As mentioned, the chain is only for picking the rear of the mower deck up so it doesn't trail on the rear wheel (and it keeps everything from binding and bending things
