Air Filters??
/ Air Filters?? #21
I have a photo of an oil bath
air cleaner for everyone
to see if desired.
The oil bath air cleaners efficiency
is also increased a huge amount by
using a cyclone precleaner on the
intake of the oil bath air cleaner.
I will try up load it shortly
/ Air Filters??
You might want to tell Kubota they have it all wrong in their service manuals:laughing:
The BX24 workshop manual on page G-18 specifically says to blow out the filter with compressed air under 30 PSI and to replace it after every 6 cleanings:cool:
They even go on to say if oily to wash it in detergent, rinse well, dry it, and inspect it for damage.
YEP-- the L2800/L3400 has the same directions...
J
/ Air Filters??
to see if desired.
Oil bath...
I read somewhere NOT to do this as it will cause dirt to stick to the filter....
maybe that was for small pushmowers etc...
FYI-- I did not get that filter today....
later,
J
/ Air Filters??
TEG--- do you have and inner and an outer?
I could swear I only have a single filter...
J
/ Air Filters?? #25
You had an oil centrifuge on the mercedes
Nope - I had a bypass filter - but it wasn't a centrifuge: it was actually a specially modified MotorGuard filter, modd'ed and setup by an old boy from down in Texas, by the name of Ralph Woods.
MotorGuard likes to sell 'em for air filtration these days (alot of folks use 'em on plasma cutters .....), now that the original founders have retired ..... the new management guys don't wanna hear about no steekin' oil filtration ....
It used a single roll of TP (toilet paper) as the filtration medium and flow was restricted by means of an orifice (.0625" IIRC), to ensure that it wasn't starving the engine of oil ....... filtered down to the sub-micron level:
/ Air Filters?? #27
/ Air Filters?? #28
I haven't gotten around to getting the mounting brackets and plumbing for the Spinner fabbed (it requires a 1" ID drain back to the sump/oil pan) - the Sprinter's engine compartment doesn't have alot of extra room, so it's a bit of a challenge .......
/ Air Filters?? #30
BTW, I forgot to mention it .... with 960 hours on the clock, I'm on outer air filter No.2 for the B2910 ....
No. 1 was blown out with low-pressure compressed air repeatedly at various times, and washed with water and liquid dishwashing detergent at least once - probably twice, can't recall exactly .....
When I wash them out, I like to fill a bucket with soapy water so that the level comes just up to the top of the filter (but not over), when the filter is placed in the bucket vertically ... low enough so that no dirty water (and dirt particles) will come over the top and into the opening to the inside of the filter.
Agitate up and down, and side to side to taste .....
No 1. is sitting up in the shed, waiting to be washed yet one more time ....
/ Air Filters?? #31
You folks have got me all confused on filters again.
I can recall some of the Toilet paper rolls for oil filters from many a year ago. Seemed they went out of fashion quite quickly.:)
My little Kubota B7100 had inlet with a cyclonic type prechamber that caught the big stuff. It only had one air filter and when plugged it would effect engine performance. Think most of the other equipment has something prefilter that will be similar.:D
I can recall the oilbath air filters on the farm tractors and even cleaning them.
Then there is being told by the Job site Cat Mechanics that dry element filters were better. That's why Cat used only dry elements at the time.[ 40 years ago]:D
Now I can see were the dry element filters, it's not really paper, can be designed to a particular limiting pore size but haven't a clue how that would be done on an oil bath filter. :)
/ Air Filters?? #32
J
It's an Option, when I asked my dealer about it, I was told that I didn't need it. The reason I changed my air filter (2x) was the fact that I used my tractor a bunch building a couple of roads and it was very dusty. Now that the roads are done... I'll be changing my tune instead of air filters...
/ Air Filters?? #33
Uh-oh .... :D
Yup - in the world of "Madison Avenue" Advertising and Public Relations (which is often fraught with misleading info - if not blatant, outright lies) toilet paper as a filtration medium wasn't exactly great "positioning" - it lent it itself to much derisive commentary, and "potty humor" .....
Of course, that completely skips over and totally ignores what the actual results were, and that, as a matter of course, paper itself as a filtration medium isn't an uncommon thing ...... it just can't be that type of paper:
NOOOOOO !!! .... Henry please, please tell me that you didn't put that paper in my Ford ..... :laughing:
One has to ask themselves:
Who would be interested in seeing such a product not succeed ?
Two parties come immediately to mind:
1. People/companies that refine and sell oil ...
2. People/companies that make and sell a different type of filter .... (one that is much more expensive, in terms of replacement)
And there is a third factor which plays into it, and goes back to a comment that I made earlier in this thread, which has to do with the efficiency of a filtration media to capture dirt and contaminants, and is part of the "magic triangle" of filtration:
Filter efficiency vs. overall size of the filtration media vs. filter longevity (frequency of change or replacement)
If a filter is extremely good at capturing even the smallest contaminants, it is not going to last as long as one which isn't, given equal sizes of filtering media and the same dirt load - because it will clog up and need to be changed sooner.
People, to some degree, are often lazy - vehicle manufacturers, realizing this, then figure out a way to come up with a so-called "better solution" (albeit a more expensive one) - which allows for changing the oil filter less frequently (but changing the oil more often than one would actually have to, if one were using a better filter) - and then this is sold as an "advantage" - even though it results in poorer filtration, costs more overall, and allows wasting a valuable, finite resource.
Dependency on foreign oil a problem ?
Well, consider this: In the United States there are roughly 247 million registered motor vehicles on the road today - cars (136 million), trucks (110 million), and buses (1 million) - which doesn't even take into account other things like tractors and construction machinery, etc.
Let's just look at cars - since it is doubtful that very many of them are running a bypass filtration system (many larger trucks and busses probably already do run one - since the economics are more significant, in terms of a commercial operation)
Now imagine that you eliminate 2 out every 3 oil changes (a very conservative estimate) .... figuring an average sump size of 5 quarts .... that's a total savings of 1,360,000,000 quarts of oil (yup - that BILLION with a very big capital "B") .... or 340,000,000 gallons of oil .....
That is not an insignificant amount of a finite resource, nor is it an insignificant cost (to our economy)
The real beauty of the MotorGuard system is how cheap replacement filter media is, and how relatively clean and easy it is to change:
Let the filter drain for 30 minutes or so after the vehicle is shutoff, unscrew the T-handle and swap the media and reassemble - the actual media change takes maybe 5 minutes .... if you are really slow ....
Of course, as with anything, the proof is in the pudding of actual results ;):
/ Air Filters?? #35
Back about 66 the company I drove for had some of them toiletpaper filters installed to see if they were worth it or not. Now back in that time oil filtering just wasn't what it is today, and supposedly oil wasn't as good either, so it was pretty much a matter of learn as you went.
In the 50s a lot of manufacturers didn't even have what you call full flow filters on engines, and nobody had filters on transmissions or rears. I don't think anybody even thought of filtering antifreeze but then we were mostly running alcohol for antifreeze if we ran antifreeze at all and the way that cooked off filtering wouldn't have been worth much anyhow.
Me and Mushmouth were driving a matched pair of tractors and pretty much hauling the same route mile for mile ahuling more or less the same weight to boot. The dang filters on them engines were long suckers in what you'd want to call long 1# coffee cans with a bolt up through the middle, and a real pain in the patootie to change I tell you. I believe we changed oil about every 4000 miles back then, and filters too. Later on the company went to changing filters every 5000 miles and adding oil to fill up the new filters, and doing a complete oil & filter change every 10,000 miles. The heavy hauling trucks like mine got changed more often cause our engines worked harder for every mile we went. My tractor got a pair of them chrome plated Frantz filters, had em mounted on the back of the sleeper cab cause there was noplace else to mount them, and Mush's tractor didn't.
Now like I say we went everyplace together, burned the same fule and had the same lube oil. There was even a little plastic dome thing you could sort of see thru in the return line to the oilpan on the engine, and it was a good thing the fellow who installed them filters told me about black oil not really being dirty or I might have parked her after the first few hours. He explained that black was just a thing that happened to lube oil with ash type deterggent in it when it got hot, and proved it tight there with one of them coleman stoves and a frying pan. Now we was probably overly protective of them engines first few thousand miles, pulling the dipstick twice a day and such, but that's the way you run a test.
About the first thing we noticed was one day we ran heavy and slow with rain coming down all day, and that evening when we pulled the sticks after supper Mush's truck showed the foamy whitish looking oil you expect in them circumstances, and mine looked just fine. I sorta figured that was cause them rolls of toilet paper was taking the water out of the oil. That was what the brochure said it would do and it sure seemed to.
We also had to draw oil samples every so often and send them off to a lab, had these glass jars with a lid that slipped into a cardboard tube that had a screw on top just like a mayonase jar that was all labelled up so all you needed do was find the postoffice and ship her off. We ran that test for the better part of a year, and every time it came back that Mush had contaminants inhis sample and mine was clean. Only drawback I saw to them filters was having to change the toilet paper. I sure didn't want to be having to walk in no store and ask for 6 rolls of TP for my truck and have people look at me all funny so I got a cardboard box and carried 6 rolls in the sleepercab. I forget where we were this one time but the fellow at the truckstop gave me some mouth about my truck needing to wipe its a** so when he wasn't looking me and Mush went inteh bathroom there and swapped out all their paper for the stuff I pulled out of my filters. I bet that went over real good when some driver was sitting there doing his business and reached for the paper, but we didn't get to see cause we hauled out of there right quick. Another time we got the bright idea to see how one of them used rolls would burn and had us a little campfire right there in the lot. Let me tell you a roll of TP full of oil burns a long time and it burns hot. They did come in handy when we was up north in wintertime, for when youhad to thaw out a frozen air tank. You could jam a used roll into a paint can and carry it in the toolbox, and when you had a froze up tank just stuff a stick inthat roll and use it instead of a roadflare to thaw the tank.
Well after that first year of testing the company had them filter stacks put on just about everything, and they worked out well. I don't think we went to more time between oilchanges though. Also don't ever recall one of those engines needing any rebuild ahead of schedule because of them filters either. The mechanic in the shop saved the used TP and burned it in this woodstove he had in the shop to stay warm with. He figured they worked better than busted up pallets, and you could use em to get a fire started too.
/ Air Filters?? #36
Real results but I don't know what they mean!:confused2::ashamed:
Trying giving the following link a read and see if it makes more sense:
Report Explanation
You can hold your cursor over various items on the report and it will give an explanation of what it is.
One thing to keep in mind when looking at a UOA (used oil analysis) is that in terms of wear metals, you mostly are looking for trends (somewhat opposed to a single number or value ....)
/ Air Filters?? #38
Hello Egon,
If a cyclone precleaner is used on the inlet of the oil bath precleaner it equals or surpasses the filtration of a paper filter with zero restriction affecting the Hg. pressure gradient:thumbsup:
They did not like cleaning them thats why; because they needed to wash them with diesel fuel or wipe them out with a lot of paper towels and properly dispose of them.
leonz
/ Air Filters?? #39
Oil bath...
later,
J
No,
wont happen because the mesh captures the splash if any; Mann filter has a combination oil bath/dry canister units which are small in size and you can make them even more efficient by placing a cyclone precleaner it and make the oil bath air cleaners even better-equal to or better than paper filters.
It will happen if you over fill the oil line in the base but otherwise no, think about why they tell you to oil the foam air filters that go ove the paper ones- UH HUH
/ Air Filters?? #40
All technical specs, engineering data, and physics aside - our local Kubota dealer will tell you he replaces/repairs more diesel engines due to lack of maintenance on air filters than any other reason. He notes on single-element filter systems - to never clean element, always replace. His background was a diesel mechanic for a motor line company before ending up as owner of a tractor dealership.
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2012 PETERBILT 386 (INOPERABLE) (A65643)
2012 PETERBILT 386...
2020 VOLVO EC140EL EXCAVATOR (A65053)
2020 VOLVO EC140EL...
250 bu Gravity Wagon (A66408)
250 bu Gravity...
