Air Filters??
/ Air Filters?? #1
RadarTech
Elite Member
North Carolina
2007 Kubota L3400, YANMAR YT359C
Folks,
I am in a quandry..
Coming up on the 300 hour mark and I've run my tractor in alot of dust and dirt. I have blown it out 3 times (100, 200 hours, and 250-- oil changes just did it) The book says to replace once per year or after 6 cleanings... When I went to Messicks website to check on a replacement it mentioned an inner and outer filter... But my book only covers a single element...
What do yall think? replace it for ~$18 or so...
and what about the inner/outer and then the single element? which do yall have?
It is an L3400 MY2008..
J
/ Air Filters?? #2
Dusty is relative, I find I have to blow out my outer air filter every 10 hours or so, and open the evacuator valve on the bottom to let out the big chunks. I've replaced the outer filter twice in 150 hours because after a half dozen or so cleanings it starts looking pretty grungy, never replaced the inner, seems clean as a whistle. I mow in tall grasses with all kinds of seedheads and tufts, that's what I get in the air filter. Sometimes I have to clean the air inlets on the grill and the radiator screen a couple times during a few hours of mowing because of all the blowing vegetation. If you're just in dirt and dust, maybe it doesn't have as much effect.
/ Air Filters??
wow...
I never thought about cleaing it that much...
One thing that made me think about this tonight, is that I was losing some power on my last drive down the road...
I should have had more speed in high-gear....
It's too late to go out and check, but I will in the AM....
J
/ Air Filters?? #4
If you're worried about when to clean the primary intake filter element, install an air filter service indicator; it's manometer of sorts that shows your peak intake vacuum reading.
You probably have a guideline about replacing you secondary element in your service literature; guidelines I've seen say to change it for every certain number of times you service the primary element.
If you have a two element intake filtration system, I'd suggest that while you can get away with cleaning the primary element under some situations(never with compressed air!), play it safe and just replace the secondary element rather than cleaning it.
/ Air Filters?? #5
For air filter changing the conditions worked in should set the interval between changes. This you will have to determine yourself to the best of your ability. The manual can't help.:thumbsup:
/ Air Filters??
hmm.. Well I think I will go get one today as I will be right by there....
J
/ Air Filters?? #7
I'm on my Third air filter (250 hours), I blow them out a couple of times but mine get almost black so I replace them for the piece of mind. Anyone want to have my old air filters, let me know :laughing::laughing:
I buy filters/oil from a local dealer that gave me a free hat when I asked about buying a hat... :thumbsup: (my original dealer is no longer a dealer)
/ Air Filters?? #8
I "generally" go by my manual, but filters don't cost that much, so I don't clean mine too many times before replacing.
/ Air Filters?? #9
Please, Please dont blow them out dont blow them out!!!!!
You will risk having pinholes in the air filter and that is not good for your engines.
The secondary filter is what is referred to as thue safety filter which is the last line of defense for the engine.
As they are a paper elemement filterthe paper thickness is what regulates the air pressure and flow entering the engines air intake.
First and foremost please do this for my own sanity:
The inner filter MUST be changed everytime the outer filter is changed thaey are designed to work in tandem with the outer elelement to clean the air in two passes and cut all the dust and dirt from the air stream intering the air intake on you orange beast of burden/toy/tool/pet/critter.
The air filter manufacturers do not recommend blowing them out or washing them as some in the business are doing as it compromises the integrity of the air filter construction and weakens them as well which will create pin holes and separation at the base of the paper folds.
You can add an an oil bath precleaner with a DUST CYCLONE CUP" precleaner-this is accomplished by using a a primary baffle with vanes that slow the intake air down as it enters the precleaner which allows 95 percent of the heavy dust to enter the dust cup to be ejected and dropped into the cup which keeps the heavier dust from entering the oil bath separator to you tractor to totally eliminate the dust and dirt with or with out the paper element. as a final filter.
The single element filter is a very fine filter and should be thrown out and replaced every ten ours if you do not have an oil bath precleaner.
You can order air filters from a lot of places-NAPA being one in particular is one of them where you could buy them by the case and they are made to one set standard that they have to be tested and guaranteed for which is this:
The air filter paper is folded like a bellows as it increases the surface area available to the air filter to allow it to filter the air entering the engine and maintain an unrestricted full flow of air at the full intake Hg. required for the engine to operate properly for the engines operatin g hours and recommended service intervals
Hg. refers to the actual water gauge pressure created by the PRESSURE GRADIENT the engine creates by and with its air intake or the air filtration system with the 4 cycle operation of the diesel engine.
The PRESSURE GRADIENT is created by combustion air required by the engine, the size of the air intake, and the filters TOTAL SURFACE AREA which is the unfolded square feet of suface area the treated paper element for the single element filter in the small engines, or the case of the dual element filters for the larger engines with the inner safety element and its primary element which create the 2 layers of filtration safety for the engine.
The paper air filter is an out growth of the of the oil bath filter as all early engines had oil bath air cleaners which were and still are the best type because they have the largest filtration area square feet for dust and dirt separation.
The paper filters rubber sealing gasket is the final line of defense for the engine, it is pressed against the end of the housing to seal the outer elelement with a gasketed wing nut which also seals the safety element which is held in place by the sendary filters gasketed wing nut.
About the restriction indicators on todays air filters:
a. they fail.
b. they fail.
c. they fail.
d. the design is simply prone to failure.
e. they were designed to fill a need at the lowest cost per filter unit.
The springs and release buttons in the indicators become weak and they will eventually become useless if they are not replaced, The tattle tales also collect dirt which affect their ability to work- they were an out growth of the filter not be changed when it shoud be anyway due to dusty environments.
The smaller tractors design affects the air filter performance where the filter is entirely enclosed by the engine hood and skid plates which create additional restrictions to air flow AND also aid in creating pathways for much more dust to enter the filter.
a lot of tractors and farm machiery have filters mounted above the cabs on some tractors or have oil bath precleaners installed ahead of the paper filters. Many stationary engines and rotary lobe blowers or regenerative blowers have very large oil bath air filters to clean intake air and allow full flow at all times.
An air filter is cheap insurance for any engine, the car and truck engines have mutli pass folded felt elements that aid in filtration and allow full flow of combustion air to enter the air intake.
If you have a single element air filter simply change it every ten hours if you have dusty conditions-dont wash blow it out or bang it to clean it as it will damage the paper folds which become brittle with age due to the paper coating applied to them to aid in filtration.
Adding an oil bath precleaner will only aid your tractor to live longer and breathe better with no restrictions
You can also buy an oil bath and paper elelement air filter unit for your size engine if desired and also the tubing required to install it as well as the mounting brackets.
The smaller kubota tractors are an item that fills a niche market or itch market if you like several of them :^)
Kubota would gain much and hafewer problems buying three and four cylinder air cooled engines from Duetz Farr/ or AVCO_dont even know if they exist anymore- the american builder for these tractors as they require less space and will have no issues with cooling due to the simplicity of design and maintenance
leon
/ Air Filters?? #10
The secondary filter is what is referred to as the safety filter which is the last line of defense for the engine.
Yup ........ that's true ......
As they are a paper element filter the paper thickness is what regulates the air pressure and flow entering the engines air intake.
I would suspect that the porosity of the filter paper is probably what actually does it ......
The inner filter MUST be changed everytime the outer filter is changed they are designed to work in tandem with the outer elelement to clean the air in two passes and cut all the dust and dirt from the air stream intering the air intake on you orange beast of burden/toy/tool/pet/critter.
Ahhhhh .... I don't think so ..... at least not on my B2910 .....
The inner filter (which is a screen) is designed to keep boulders and other large objects, such as your bathtub, lawnchairs, and kid's tricycle, out of the engine .... it just ain't gonna do a whole lot as far as dust (dirt mebbe .... if they are large clods .....)
And Kubota DOES NOT necessarily recommend changing the secondary every time you change the primary ....
The air filter manufacturers do not recommend blowing them out or washing them as some in the business are doing .....
Well, that might depend on which manufacturer you are talking about ......
But at any rate, they are in the business of selling air filters now aren't they ?
Might depend on how much air pressure you are using ... ;)
Jeez .... what's your day job ..... parts manager for dealership ? .... or sales rep for a filter manufacturer ? :p
Internal combustion engine air filters can often go far, far longer than what is commonly believed (as a consequence of air filter manufacturer propaganda) - although in the case of tractors, which often operate in much dirtier environments - that's much less the case than with other over-the-road vehicles - as an example:
I have an '06 Dodge Sprinter (Mercedes) that gets driven over the road .... it's a diesel engine and has a filter minder .....
I've changed the air filter exactly twice since we bought it new ..... first time was at 123,000 miles ...... and the second time was at 271,000 miles .... neither time was the filter minder indicating a restriction and the vehicle was running fine (no loss of performance) .... the vehicle now 282,000+ miles on it.
Having said that, I do agree that equipment that operates in a "severe service" environment does need more care and maintenance than others do ....
/ Air Filters?? #11
Very good post.
/ Air Filters?? #12
I can see the post as being over the top but informative ...and that's totally fine with me. The filters are cheap enough to not worry about it.
I was thinking people would think what I did was over the top :laughing: :)
/ Air Filters?? #13
UH HUH,
I worked undergrounfd in mining for 22 years as a mine laborer and journeyman mechanic.
the paper coating- yes
The safety element requires changing at every interval or dependent on operatiing conditions as the fine dirt load is only doubling in the safety element.
you can slice paper with an air knife or a pin point jet with a safety air nozzzle (low pressure)so thats a non starter because as it ages it becomes more brittle from heat due to friction from air entering the element.
Kubota simply purchases air filters/systems that fall within the engines operatining requirements/compartment sizecont-
We had a herd of ELMAC Boss Buggys which were built/modified for coal use that had the three cylinder kubota engines with the the single element which were small 2 wheel drive Kubota farm tractors that were imported and modified installing catalytic converters, FOPS canopies and rear storage and seats behind the operator, as well as adding fold up seats for two more people up front on the added fenders, and a wider platform for the two seats which included a full fender over the front tires on both sides to allow the unit to carry 7 people which was the normal crew in a small coal section for example.
Cont- which also fall prey to tier 2,3,4 diesel exhaust issuesand that mess which would not be an issue if water scrubbers were used AND MAINTAINED which is why they are not sold that much any more buut still availabe for after market use.
As imentioned before the tattle tale is not foolproof which has been my experience with diesel engines in underground and surface use.
The air filter industry has also manaufactured air filters and the precleaners to within a machines engine compartment or within easy piping distance.
They have forgotton one simple rule which is this:
The less restriction you have on the pressure gradient created by the intake air in Hg., the easier your engine works at lower fuel consumption rates to provide the torque required to do work-which is why I mention the oil bath intake air cleaners for aftermarket use a lot and the very large oil bath air cleaners for blowers and very large deisel engines with large engine platforms.
But they are building/designing a product to fill a need which is the 4 cycle internal combustion engine.
If water scrubbers were installed on gas lawn mowers-riders or pushers they would not emmit 4 times the air pollution a car or truck does as they are not considered a big polluter due to the engines smaller cubic inch displacement.
Kubota is not required to install catalytic converters on the diesels because they are nit required to so with the emmisions standards for tiers 1,2,3,4 because of the direct injection engines they use.
If they used an indirect injection engine they would be simpler to maintain and repair. If they used the Duetz design with the two and three cylinder air cooled engines they would not have radiator issues due to plugged screens and would have lots of room for an oil batrh air cleaner.
The reason the air filters are where they are is simply one of convenience as the small engines arew typically set in an operating box for the gen set or pump or thresher which was their original purpose and the size of the engine and its narrow width aloowed it to be used for other machines like walk behind sheeps foot rollers, vibrating rollers, portable screeners etc.
Another example is the L+M Mesabi radiator which has replacable core elements and allos allows beter cooling with out a radiator core which would save a lot of grief for the folks with chaff screens as they would not be needed-but the kubota engines are also victim of their success.
As the smaller engines were originally built for other purposes like pumps, gen sets, rice planters, threshers, compact track drive rice combines etc. they were used to fill a need for the compact tractor market and the CUT were built around the engines just like continuous miners are built from the bottom up.
The Donaldson inner air filter safety element cartidges I had to deal with were pleated paper with coatings and did clog and kill engines from dust or were so badly fouled they collapsed due to the pressure gradient created by the intake air streams effect onn the outer element which in turn collapsed the inner elelements.
And of course if they had installed oil baths ahead of the paper elements
which is done in high dust/trash environments the engines would have lasted longer but I was told to keep my mouth shut and I did not know anything.
Most if not all the early automobiles and trucks had oil bath air cleaners because the engines were within a stable platform being the car frame and they worked for years until they started making larger gas engines and diesel engines.
They would still be in use today if the engines had remained the same size and used diesel for the most part in my opinion.
/ Air Filters?? #14
Very interesting thread.
/ Air Filters?? #16
I can see the post as being over the top but informative ....
Very - it contained some good info.
Yup - me too :D .....
I just didn't want the impression left - as a consequence of the poster being unfamiliar with what the secondary element actually is on certain Kubotas - that the secondary element on at least some Kubotas need to be changed every time the primary is changed.
For me, and perhaps many others, this would get unnecessarily expensive and is, quite franly, really just a waste of money - it gets you nothing.
My secondary screen is about $50 .... and after 960 hours, is in good shape.
FWIW:
123,000 miles ÷ 60 mph = 2,050 hours of operation
150,000 miles ÷ 60 mph = 2,500 hours of operation
The above are best case scenarios (in terms of hours, actual hours likely are significantly higher) - and do not include idling time (imagine living in cargo van for as much as a couple of months at a time .... often having to sit for days waiting on a load ...... and sometimes winding up in such places as Laredo or El Paso, TX ...... in July or August ..... with temps in the triple digits ..... :shocked:)
/ Air Filters?? #17
UH HUH, I worked undergrounfd in mining for 22 years as a mine laborer and journeyman mechanic.
Well, I ain't gonna bore ya with my complete resume - but it does include some time "down under" ...... breathing a fair amount of scrubbed diesel exhaust (PG&E pumped storage hydro project, Lake Wishon, CA in the Sierras) ..... and owning an automotive engine rebuilding shop.
The safety element requires changing at every interval or dependent on operatiing conditions as the fine dirt load is only doubling in the safety element. <snip> The Donaldson inner air filter safety element cartidges I had to deal with were pleated paper with coatings and did clog and kill engines from dust or were so badly fouled - they collapsed due to the pressure gradient created by the intake air streams effect on the outer element which in turn collapsed the inner elelements.
You actually might want to have a look at the safety element that I'm talking about - it ain't paper - it's a wire screen.
It ain't a paper element like on some B&S that has an oiled foam primary on it.
Oh ..... is that the way it works ? :rolleyes:
Hmmm ...... most of the OEM manufacturers I'm familiar with (names you would know - like Ford, GM, Chrysler, Honda, Toyota, GE, Case/NH, CAT, Deere) will quite spec and design (either in-house, have their suppliers do it) what they need and want their suppliers to produce that meets their specific requirements.
Yeah - but you can bet that a manufacturer - who has warranty obligations - is going to ensure that whatever they stick on there is at least going to be adequate to the task. To do otherwise would be foolish.
It's always a trade-off: filter efficiency (which usually means more restriction, less porosity) vs. maintaining adequate flow for the engine.
Most folks often don't realize that a dirty air filter will actually filter better (up to a point, that point being where the filter collapses and is no longer filtering) than a clean one ....
What are you thoughts on bypass oil filtration ? :D
I had a bypass oil filter on that Sprinter at one point - ran the sump for over 50K miles on the same oil (just make up oil) ..... when I finally changed it out at 50K+, I had the oil tested of course, and Blackstone said still good ....
Thinking about sticking the bypass on the Kubota .....
And of course if they had installed oil baths ahead of the paper elements which is done in high dust/trash environments the engines would have lasted longer but I was told to keep my mouth shut and I did not know anything.
My guess is that you know quite alot (but I do also know, that at least in the case of my particular Kubota engine and it's secondary filter, that you are not familiar with it, specifically) ....... I'm finding the oil bath air filter info quite interesting - I was aware of them, but it's always nice to hear from someone with actual experience :D
/ Air Filters?? #18
OK, back to the reality of tractor ownership. Nobody I know changes air filters every 10 hours.
I blow out my air filters with compressed air until when they are held up to the sun no light comes through. Then they are replaced.
Usually the filters are tapped on the wheel to get rid of the loose stuff and then blown out from the inside first and finally the outside. Clouds of dust come off.
The inner filters (when used) have been blown out but there is never a speck of dust that comes off of them. As a result, I declare that my method works. :laughing:
BTW, the Kubota manual for the M7040 recommends periodically washing the air filter with water.
/ Air Filters?? #19
You had an oil centrifuge on the mercedes and removed it, WHY?
I am unsure if the kubota would have the speed for the centrifuge, the other issue is placement as they are typically mounted at the end of the indirect injection pump with a coupler that also attaches to the cooling blower for the duezt engines.
I know that Racor makes or did make an oil filter for very fine filtration at one time.
when filtration is reduced combustion air is reduced, and fuel is wasted
The folded felt air filters were an answer to a prayer for some engine builders adding huge amounts of surface area for filtration.
Are the head race and tail race tunnels for that mess still intact?
I have forgotten about the PGE projects but was that the one with pumped hydro storage up hill after going through the turbines or gravity down hill and discharge to waste.
the oil bath filters are the best ones and you can mount mutiple units together for engine intakes to clean the air it needs for combustion.
My link for oil bath air cleaners should still be here if you search for it.
the oxy catalyst scrubbers we had were no match for water scrubbers with thier efficiency because the shovels had to be left idling as they leaked too much air and the PTX purifiers were no better for the same reasons- they would never clean them with an oven to temperature with a catalyst oven to burn off the residue.
the use of the high sulphur fuels with the dry scrubbers was bad because of the sulphur and it created a continuos fog no matter how hot we ran them because we never cooked the pellets to clean them nor did we use an manomometer to determine the efficiency of the purifier beds in the scrubbers. nor did they check the PTX purifiers.
most if not all our engine issues came from low fresh air volume and poor air circulation which was always a huge issue and they are 17 miles out now with a booster fan set that is soon to reach its limits if it has not all ready.
/ Air Filters?? #20
You might want to tell Kubota they have it all wrong in their service manuals:laughing:
The BX24 workshop manual on page G-18 specifically says to blow out the filter with compressed air under 30 PSI and to replace it after every 6 cleanings:cool:
They even go on to say if oily to wash it in detergent, rinse well, dry it, and inspect it for damage.
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2002 Pro Line 20 Sport Boat and Trailer (A65579)
2002 Pro Line 20...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
