YM 2000 sputtering
/ YM 2000 sputtering #1
Heiny57
I have had this thing for 7 years and not a problem till now. My son was bush hogging and it started sputtering and died,and would not restart. I have had to leave it outside for a couple months and it was low on fuel so I thought it could have got some condensation in the fuel. I bought some ISO and drained the bowl poured a little in the bowl and it started right up, which surprised me. I filled the tank and added some ISO to it also. Today I box bladed for 5 hrs and it started to miss and run rough, I was about done so I got it back to the house and shut it off.
Any suggestions where to start. I am going to change fuel filter, but it is not old. Plugged injector? Does any one use Sea Foam?
Thanks for any help.
/ YM 2000 sputtering #2
i was thinking a bad fuel filter. Change it and then prime it useing the screw and cranking to get all the air out.
It quit the first time soon after starting, I don't think it's overheating but maybe.
What happens when the fuel injectors get dirty, I would assume it would be a constant thing, not intermittent. :confused2:
/ YM 2000 sputtering #5
The owners manual for my 2002d under trouble shooting with the title "engine runs irregularly or stalls frequently", #4 listed is dirty or faulty injection nozzles. I agree with your thinking that the injectors would be constant but I don't know. Have you shined a bright flashlight in the tank and have confidence your fuel is clean and uncontaminated? Is your tank vented? Might try running with loosened fuel cap. Didn't remove the little fill strainer did you? When you say you don't think it is overheating do you have a gage or a light? Is any water boiling over to the overflow bottle?
Over heat light works, It happens every now and then when I bush hog and get a lot of chafe in the screen, I just washed it out the other day. Screen in place in tank, forgot about tank vent,,,, could be, I need to change my fuel filter tomorrow.
What is a good injector cleaner, if there is one, to add to fuel before I tear something down.
I use sea foam in all my gas vehicles, it says its for diesel to.
/ YM 2000 sputtering #7
I don't think it's injectors. One might get crudded up, but never both simultaneously. In my experience crudded injectors made starting difficult (blobs instead of vapor) but as soon as it fired it ran the same as always.
I think this points to fuel starvation.
Any air leak between the tank and the pump can cause it to serve air instead of fuel. This would be the filter o-ring, or a bad hose or hose connection.
Or starvation could be crud blocking the tank outlet, or blocking anything downstream clear into the pump intake. When it stalls you might pull the hose off at the pump and see if it drains freely.
A mistake a few of us :D have made is to screw on the fuel tank cap so tight that it is airtight. This starves the pump.
Keep us informed as your investigation moves along!
/ YM 2000 sputtering #8
I use a smaller hose for the return back into my tank no leaks or issues. I think I would start at the tank drain and clean it.Check that my fuel lines are not cracked and replace the Filter and cup o-ring. When you bleed your filter make sure you don't forget to bleed the pump also. There is a U-tube video Yanmar Tractor that will show you how to bleed both.Not much to it when you see how it's done.
Carey
/ YM 2000 sputtering #9
was just thinking about the way you described it running ( sputtering )
sound like water getting into the Cylinders through a blown head gasket, not meaning to alarm you, But was the reason for mentioning if could have been run hot? Ya know the story on these Yanmars:cool: especially the ones with no water pumps ;)
/ YM 2000 sputtering #10
A 2000 has a water pump, but not saying the rest of what you say could not be the case.
Thanks guys for all the help I hope to get back to it tomorrow, I am putting brakes on 66 Newport right now. Never enough time.
/ YM 2000 sputtering #12
I'll give you my two cents. My 226d had the same symtoms as yours.
I noticed this black like slime in the fuel filter. I took of the hose at the tank and nothing came out, then I saw this black like slime blocking the way.
I decided to do the right thing and remove the tank. It was a slight bit of pain, as I had to remove the steering wheel, disconnect the electrical connections, the ignition switch, decompression lever, tach cable, disconnect the power shift. Once I got the tank out, I drained it completely, filled it with some diesel and shook it violently, drained it again, repeated that process a few times, then drained again, and this time put the air hose inside, and blew it out from both the top and the where the diesel line hooks up.
After I put it all back together , it runs as if new. Not one miss, feels stronger than ever.
I'm not sure what the black gunk was, but I am most sure that was clogging the line thus limiting fuel and causing air to get in the line.
/ YM 2000 sputtering #13
I had the same issue. When I bought the tractor it had been sitting for a year. ran great in the dealer parking lot. until I brought it home. I drained all the fuel out of the hole system and cleaned everything and changed filter,removed some fuel line that someone had spliced in. just after pump to just before the tank(return line:confused:).couldn't tell you what the thinking was behind it..??
She hasn't missed a beat since.
/ YM 2000 sputtering #14
My 226d ... bit of pain, as I had to remove the steering wheel, disconnect the electrical connections, the ignition switch, decompression lever, tach cable, disconnect the power shift.
Wow! YM2000 is far simpler.
Drain the tank and take off the fuel return hose. Then unbolt two tank straps and remove the fuel outlet hose underneath. Lift out the tank. Two minutes max, after whatever time it takes to drain the tank.
I discovered a flat piece of transparent varnish (or maybe plastic from a fuel jug) the size of a whole fingernail fluttering near the drain hole in my tank last time I drained it. It hadn't caused a problem, but it looked like it could have.
That black gunk sounds like it was made by the diesel-loving bacteria that can live at the water/diesel boundary when there is a small amount of water anywhere in the system. It is famous for plugging fuel filters.
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2025 SDLANCH 20x 30 SDLC2030GT Heavy Duty Greenhouse Tent (A64194)
2025 SDLANCH 20x...
