John Deere Auger
/ John Deere Auger
Oh, the stubs were fine. They are compleatly fine and i am glad they were because i cant imagine a new one would be very cheap. Since the frame and PTO shaft were a little bent, it caused it to rock my tractor when i used it. Now that they are both strait again, that should have fixed my problem. Anyways, I just put my auger back together. I think it looks pretty good for a $30 auger. I cant wait to get my new JohnDeere decals on thursday. Then i should be compleatly done with the restoration. I still am wondering what the two pieces of steel were for? Shown in picture 6, I dont see the point of them. i put them back on so i wouldnt loose them but I know they definatly were not for hydraulics because the 4100 Deere it was on had no rear hydraulic ports. Does anyone know what they are for?:confused:
/ John Deere Auger #22
Sure look like add-ons, as they are not green, they have an oversize bolt holding them in place for the relatively thin metal, and I'd leave them for a conversation piece. :D Or toss them and paint over with green paint :)
Good job getting it back in like-new condition.
/ John Deere Auger #23
Just guessing on this, maybe someone's idea of an attachment point to hang it up inside a barn.:confused3: Hey, it might work. Great job on the reconditioning.:thumbsup: Wish some of my implements looked that good....Dan.
/ John Deere Auger #24
JD3720,
That PHD looks like new now.:thumbsup:
The handle I was referring to is 1/2" pipe if I recall correctly, I will measure mine to see how long it needs to be.
Those two silver clips you keep asking about are add ons, not factory. Maybe your neighbor could tell you why they were there.
Did you make the new gasket and replace the seal, oil?
/ John Deere Auger
I replaced the oil and a gasket and it holds oil pretty well. I am gonna have the auger home in about a week so I will ask my neighbor what it was for.
/ John Deere Auger #26
Looking good. It looks like you spray painted part/all of it. I've found over the years of redoing stuff that rattle can paints don't hold up real well to abuse and are pretty thin even with a lot of coats. I now just brush on enamel with penetrol. It really makes the paint film a LOT tougher and more rust resistant. It also makes brush marks go away. And by brushing it you can get it on a lot thicker.
Oil Paint Additive | Paint Without Brush Marks | Flood
/ John Deere Auger #27
whitedogone
Are you speaking of JD paint in a rattle can?
I've not had your experience with JD paint.
/ John Deere Auger #28
thanks for all the comments. I had no idea what the model number was since there really arent any labels left on it. Since my last day of school is on thursday, I plan to start working on it Friday. I will take out the old seal, replace the oil, and fix some other things like the slip clutch on my tiller, and maybe replace the oil and oil filter on my Yanmar. About the handle, the handel was probably in my neighbor's shop that burned down. I will probably get a new one. One thing that i am curious about is what are the two small silver pieces on metal on the frame for? :confused: They look like a guide to run a rope from the handel rea to the tractor seat. Oh, the Deere in the old shop was a 4100. Poor thing, it only had 500 some hours on it.:(
Looks like it is leaking out of the vent. Probably due to the way it was stored on it's side.
Which seal are you planning on replacing.
I would make sure it has enough oil in it for sure.
D.
/ John Deere Auger #29
On that bracket - I wonder if it is there to slid something from the rear like a long piece of steel to help pull the auger down. I know before I added the hydraulic down force kit on my post hole digger - we would have to jump up and down on top of the gear box to get it to dig at times. Yes I know - dangerous, but we had to do it. The hydraulic down force kit was not cheap, but a lot safer.
D.
/ John Deere Auger
I luckly didnt have to replace the seal, just a gasket. Yesterday I drained out the old oil and put in new oil. I didnt fill it all the way since under heat and pressure it expands and I dont want to blow a seal.
/ John Deere Auger
Today i got my new John Deere decals for my auger. They sure look good on the auger.:D:thumbsup: I also noticed recently that my auger bit is bent by rolling it on smooth pavement. Tomarrow I will bring it down to the shop and put it in the hydraulic press to bend it back. Then after It is bent back, i will paint the other half of the PTO shaft and will be compleatly done with the restoration.
/ John Deere Auger #32
Luv the way that PHD is coming along! Sure is starting to look original and purty.:cool:Awesome job:thumbsup::thumbsup::thumbsup:
Boone
/ John Deere Auger #33
Speaking about the pto shaft, I would be concerned about the length of the tube, it seems to be very short. Might be why it is bending to start with. Since the mast pivots around the top link pin, I would raise and lower the boom to mark how much of the shaft remains engaged.
/ John Deere Auger
Well today i straitend out the auger bit and painted the other half of the PTO shaft. The PTO shaft has a lot or room when on my tractor so there is a lot of area that the force is distributed. I have atleast a foot or so of PTO extra. In the picture, the smaller PTO shaft is from my tiller. I had to fix my PTO clutch.
/ John Deere Auger #35
The brackets are for mounting the stand legs so they don't get lost.
Pallet of Ground Protection Mats (A60353)
Pallet of Ground...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2007 Freightliner Columbia 120 T/A Wet Cab Sleeper Cab Truck Tractor (A60352)
2007 Freightliner...
2013 John Deere 329E High Flow Compact Track Loader Skid Steer (A61567)
2013 John Deere...
New/Unused Receiver Hitch (A61166)
New/Unused...
2025 X39 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 X39 Hydraulic...
