Your Input Needed
/ Your Input Needed #1
Toffy
Hi Everybody
I just acquired a 1948 ? LEADER tractor powered by a Hercules 4 Cly. Gas engine.
The engine is not rebuildable and possibly not easy to find.
What I have is a Continental Red Seal Engine out of a Lincoln welder. My plan is to do a conversion.
What I need is some input of things that i will have to watch for. Adapting Flywheel and clutch housings to the engine etc.
I have a machine shop at my disposal however any help would be appreciated.
Also I would like to hear from anybody with Leader tractor.
Let the Fun Begin:thumbsup:
/ Your Input Needed #2
I can offer no info on the rebuilding. I met a collector who owns a Leader tractor. He said it was built in the 40's and is quite rare. What struck me was that the grill was SOLID cast iron. It was an interesting looking machine. Here is a picture.
/ Your Input Needed #3
Toffy, why do you say your engine is not rebuildable? I had an old timer tell me how to get a stuck engine unstuck, still running it today, never removed the head or pan.
So, what facts are you basing your engine not rebuildable. Block repair has come a long way.
/ Your Input Needed #4
That's a neat picture EasyGo. I see the tractor was made in Chagrin Falls, Ohio; the same town Tim Conway's 'Ensign Charles Parker' in 'McHale's Navy' was from.
/ Your Input Needed #5
Might want to check on its value as a collectable before doing major surgery.
/ Your Input Needed
My engine is not only stuck it has major damage. In forty years of rebuilding engines I have never seen one this bad.
The tractor is very rare and worth something to a collector.
I just want the challenge of changing the engine and keeping it from the recycle bin.
I have another frame and clutch assembly. Will tear it down and see what I can do to adapt to the other engine. I have searched the net and there is nothing i could find on a Hercules Engine.
By the way besides the cast Iron grill they had no Water pump.
Water was circulated by convection only.
/ Your Input Needed #7
I think Hough loaders had Hercules gas engines in them too -- might want to look in some old heavy equipment boneyards first. Hercules made a lot of engines for military applications during the war and were eventually bought by Hupp and then White. They used the same blocks etc for both diesel and gas like Perkins did. Look up Hercules Motors Corp rather than Hercules engines -- Hercules engines were only one cylinder.
/ Your Input Needed #8
Hi Toffy,
That's very similar in respect to the no water pump Hercules engine that my Dad has in his 1940's Oliver Crawler HG 42 or HG 46 (can't recall model number) - the head has an odd shaped cast to it, where there is a riser toward the radiator on the head, causing the convection cycle to occur. Hercules were used a fair bit by Oliver. We also had an Oliver OC-3 when I was a kid, had a loader frame on it. Had a Herc 134 Cu. In. Would load up on the back of a 5/4 ton truck, backed on, bucket tucked right down tight to the deck. If I can help you with this, I do believe I have the Herc rebuild manual.
Regards,
/ Your Input Needed #9
Look in the classified under private party as there is a guy selling a Gibson that has a Hercules engine in it ..... He may be a great source for good information
/ Your Input Needed #10
Thank you mjncad.
Now that I read all the posts I remember that I have seen an old military issue welder/genset that also has a Hercules gas engine.
/ Your Input Needed #11
Hercules were very popular, and alot of them used the thermosiphon cooling system. I bat that block has a round bolt pattern like a poewer unit engine. I cant remeber the sae number for them but several bell housing would interchange back then. My have to pick a few parts between them one the clutch to get the right transmission splines. A man in Savannah TN had 5 or 6 of them wouldnt sell a bolt off of one of them. He passed away and his =kids sold them to a man for scrap. He laughed all the was to his barn with his cheap find.
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2020 Inifiniti Q 50 Sedan (A61574)
2020 Inifiniti Q...
2015 CATERPILLAR M313D MOBILE EXCAVATOR (A64279)
2015 CATERPILLAR...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
