4110 front tire
/ 4110 front tire #1
tld
Boston, GA
JD 2025r
4110 has had a slow leak in front tire for about a year. Looked it up on line and 75 dollars for a Titan 23 x 8 Multi Trac. Seems like a lot. Any other places to check like TSC?
/ 4110 front tire #2
Slow leaks are a way of life with tractors. Just slime it and you will be much happier. David from jax
/ 4110 front tire #3
Yup, get some Green Slime front TSC and "juice" both fronts up. Say goodbye to slow leaks:thumbsup:
/ 4110 front tire #4
Forget the Slime. Been there done that on my 4010. I put tubes in both front tires. Now, they maintain their pressure all the time. I was forever airing them up, even Slimed. The left one came off the rim 3 times before I finally got disgusted enough to buy tubes.
Ralph
/ 4110 front tire #5
Funny, I went the opposite way. Got tired of leaks, added tubes, which just added to the problem when it did start leaking. With tubes I had to break the tire down and patch the tube instead of just plugging the tubeless tire without dismounting the tire. Once I added the slime, no more problems. Guess to each his own...
The tires on the front of my JD are getting kind of old, and the sidewalls have started ooozing little bits of air thru the cracks in the sidewallls. Since the tires have a lot of miles left in them, I hated to replace them. Once I added slime, no more problems. Tubes would have worked but they are kind of hard to find for 16" wide tires on 15" rims.
David from jax
/ 4110 front tire #6
I got my tubes at the dealer.
Front tires are holding pressure for the first time ever.
Slime just didn't work.
Ralph
/ 4110 front tire #7
I tubes from the local auto place as they charged $12 while JD wanted to do it by the hour.
KMC Peanut Inverter Blades (A64119)
KMC Peanut...
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
2004 Chevrolet Silverado 1500 4x4 Pickup Truck (A61573)
2004 Chevrolet...
John Deere 980 30' Field Cultivator (A66285)
John Deere 980 30'...
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
