Those bed liner conveyor things for pickups
/ Those bed liner conveyor things for pickups #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I cannot think of the name of the thing you can put in the bed of a pickup that allows you to roll loose material out of the bed. It's nothing fancy, just some sort of flexible material that rests in the bed under your material, and it conveyors the material out as you turn a crank.
Can anyone tell me what that product is called?
Can anyone tell me if they are worthwhile at all? I'd say 90% of the usage for me would be just for mulch, which doesn't seem like it would pose a problem.
Thanks
/ Those bed liner conveyor things for pickups #3
I've got the same thoughts as you. LSbrown had the best take on one of those units. It went something like this "10% as good as a dumptruck, 100% better than a shovel."
Joe
/ Those bed liner conveyor things for pickups #5
Found it. Welcome to Loadhandler.com
Seems a bit infomercial/gimicky to me...
I agree. Nothing beats a shovel at times, besides, loose/light material is easy. Gotta do something to keep the body in shape! I just shoveled 9000 lbs of crushed limestone repairing driveways today. It is a once a year thing for clients.
/ Those bed liner conveyor things for pickups #6
I hear ya. I just put down 16 yards of mulch and 2 single axle dump trucks of top soil in 3 days. I was sore. The dirt I dumped and moved with the FEL 90% of the way and shoveled it in place then onto the rake.
The mulch was all hauled on my tandem axle trailer in 3 loads and shoveled off.
Chris
/ Those bed liner conveyor things for pickups #7
i have one of those that has sat in the shed for about 6 yrs now, used it once to get a load of sand for around the boat dock and still ended up unloading it all with the shovel.
/ Those bed liner conveyor things for pickups #8
Gentlemen, they work awesome. I made my own for my trailer. Then I used a small cable winch to power it. I can load my trailer, drive a quarter mile unload and be back loading again before freebird is over. :) Best part is, I can do that all day long.
It will handle trailer load of sod clumps, shot rock or whatever you have.
Still plenty of exercise getting on and off the tractor every few minutes. :)
/ Those bed liner conveyor things for pickups #9
Steve,
The exercise and freebird parts were pretty funny, but you've still gotta attach a pic. What's your winch is it electric or...human powered!
I'm interested because I'm debating converting a flatbed f350 to a dump. If you have a reasonable solution it may sound better than the work I'm thinking of taking on in the conversion.
/ Those bed liner conveyor things for pickups #10
There have been several good posts about the Loadhandler on this site. Do a search for some interesting reading. I can't recall anyone who doesn't like it after using one.
/ Those bed liner conveyor things for pickups #11
I know I'm a bad TBN'r for not attaching a pic. ;)
Here is what I used to make this thing
I bought the 42" wide tarp from Loadhandler for about $20. They are real tough.
I used a 48" x 1" iron bar and a couple pillow block bearings for the spool.
It sits in the tailgate slot and I bolted it to the sides. Hard to describe but the strength comes from being held in position on the box sides. The bolts just keep it from rattling off when not under load. It goes on and off in about 5 mins.
Originally I made a 24" crank handle out of tubing and that worked great. I ran into problems if I over loaded the trailer and the suspension compressed. The handle gets too low to the ground and you can't crank. That means you have to use a ramp to tilt the crank side.
That nonsense inspired me to weld an old lawn mower front rim to some tubing and swap out the handle. I cut a slot in the rim for the hook and wrap the winch cable around it. I sit the battery if the front corner of the trailer bed in a marine battery box. You free spool the winch and pull the tarp out to cover the bed and a few feet past. That also wraps cable on the rim for unloading. I do have to be a bit careful with the wheel wells. Too much material in front of them and it does not come out clean. The battery helps keep the one side clean. The bed liner is probably quite important in making things work well. I also positioned the spool shaft 1/2" above the bed so that it would lift slightly as it pulled.
If you have ever unloaded a trailer of tractor cut sod you can appreciate how wonderful this thing is. It is smaller scale than any dump truck but it matches my tractor nicely and suits my needs. The video is when I first tested the electric winch. Since then I have seriously over loaded that trailer while moving material on my property. I have not had a problem unloading, even after I clipped a tree and bent the shaft. :eek:
Here's the video. Enjoy.
Shall do. Thank you.
/ Those bed liner conveyor things for pickups #13
RayCo, check Harbor Freight if you decide you are going to buy a Load Handler. The price there is less than most other places. That is where I bought mine. Never used it, still in the box and trying to sell it now. You are to far away or else you could get it for a very good price ($85). I thought it might work on one of my utility trailers. Too short and too narrow, so it never even came out of the box.
/ Those bed liner conveyor things for pickups #14
Thanks for the video TIG
I have a Loadhandler 3000 mounted to Army surpus M1102 trailer.
orders a 5000 12v winch from Harbor Freight as I can haul 3-4000K, so the 1 ton likely won't work.
Was wondering about what to use for a pulley and had the wheel idea myself, but haven't found one yet, need to fit 1 inch shaft.
I can place my battery on the wheel well.
I also ordered a remote switch off ebay.
/ Those bed liner conveyor things for pickups #15
Dude! :thumbsup::thumbsup::thumbsup:
Schematic! We need a schematic!
/ Those bed liner conveyor things for pickups #16
I'll post a few pictures of some of the details. It's a simple fabrication although I did put thought into the geometry of the pulley and the direction of the forces involved.
/ Those bed liner conveyor things for pickups #17
Hi Steve,
I am also very interested in any further information you can provide. :eek:ptimist:
Also I tried to follow your video link, but I only got to a blank page with a message about a schmuck like me trying to access your private file. :confused:
Would you possibly be willing to allow me access, even if only temporarily?:eek:ath:
Any additional pictures would be very welcome as well. :yes:
We have a small wooden-decked and sided HF trailer that we were gifted by my F-I-L (too small for our bucket to easily unload, big enough to make shoveling a royal pain in our tired old rotator cuffs), and need to be able to unload it of various loads like rocks, firewood, gravel and dirt. :melodramatic:
We also could use it to help unload our F-350 which has the same size issues. :grumpy:
I'm suspect that I am getting too old and decrepit to even be able to crank the load handler even with the mechanical advantage of a 24" handcrank. :ashamed::shocked::banghead:
Thanks
Thomas :drink:
/ Those bed liner conveyor things for pickups #18
Still in the planning stage of mine. Have a 5K winch on a slow boat from HF. Having a challenge on the pulley, but my latest thought is possibly a garage door opener pulley as they are available in 1" shaft, which ought to fit the Loadhandler shaft.
David Sent from my iPad using TractorByNet
/ Those bed liner conveyor things for pickups #19
Any progress on the pics, Steve?
/ Those bed liner conveyor things for pickups #20
Sorry guys. I'm dealing with my second hard drive crash this year. I'll get new pics and fix the access to the vid.
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
429860 (A61166)
429860 (A61166)
KING 4R CHISEL RIPPER BEDDER (A63291)
KING 4R CHISEL...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
