BX2230 seat
/ BX2230 seat #1
Toyboy
Hayward Wi
Kubota BX2230D
Well I've spent about 10 hours on my '04 (new to me in Feb) and am beginning to dislike the seat. Seems to have a slight forward cant and I'm sliding around on it. Had to wear the seat belt which I don't like, to stay on it on slight slopes. I'll either have to get some butt stick-em or a new seat. :D
Is this a common problem w/BX2230 or is it just me & my posterior :eek:
If I were to change it out what would the recommendations be:confused:
/ BX2230 seat #2
That seat needs to go. My brother's BX1850 had the same one, always felt like you were going fall out of it. It would make my back start hurting because I was always pushing back with my feet to stay in it.
The seat on my BX24 is the replacement Kubota came up for it, and it is very nice. It was a direct bolt on replacement on the 1850, so I have to assume it would fit your tractor.
Messicks had a bunch awhile back for 99.00, but I don't know if they still have any. It was a sweet deal, as they are over 200 normally. Shoot them an email and see if they have any left. Hope this helps.
Edit: You might want to post Kubota specific inquiries in the Kubota board, you'll get more first hand knowledge over there. I just noticed this thread, and it's several days old.
/ BX2230 seat
Thanks, I've sent them an email. Hope there are still some available.:thumbsup:
/ BX2230 seat #4
My brother bought his maybe 2-3 months ago, and they had a few left. I think the rush on them is over, so they just may have one. Good luck.
/ BX2230 seat
Got one coming, thank's again for the heads up:thumbsup:
/ BX2230 seat #7
Toyboy, What seat did you purchase? I just spent 1 hour on my BX25 mowing and it was very uncomfortable. Thanks
/ BX2230 seat #8
He purchased the seat you have on your 25. The older seats left alot to be desired.
/ BX2230 seat #9
You mean they come worse than mine? OYE!
/ BX2230 seat #10
Oh, you've got good! How many hours do you have on the 25? Maybe the seat will break in a little better.
/ BX2230 seat
sxs191 I'll let you know how it is when I get it. Shipped today so I should have it by next Wed. The guy at Messicks told me it was a pretty good seat....we'll see.
/ BX2230 seat
Got the new seat today and installed it. Been raining and not able to get a trial run on it, but from just sitting on it in the garage, it is a MAJOR improvement over the original seat. :thumbsup:
I have to go to the auto store for some plastic plugs to fill the 6 tapped holes in the metal back like the old one has. I wonder what there for??
/ BX2230 seat #13
They should be for the arm rests - you may want those instead of plugs. What did they charge for the seat with shipping?
/ BX2230 seat
Never thought of arm rests. Seems like they'd be more in the way than helpful. I got some plastic plugs from Carquest and filled the holes. Their easy enough to get out, just unscrew them.
I think the total cost was $115 or +/- a couple bucks. What a difference, darn nice seat. Gave the old one to my neighbor...... free for the hauling.
One thing else, I think if I remove the two small springs under the seat, there will be enough weight to keep the seat switch depressed so it won't keep shutting off when I stand up momentarily. I haven't got around to trying that yet.
/ BX2230 seat #15
Thanks for the info - the armrests fold up out of the way when you don't want to use them - other than that they are handy for different situations.
/ BX2230 seat
That's pretty slick. I'll have to see if my dealer has any in stock so I can do the touchy ... feely test. Thanks
2017 Subaru Forrester (A62613)
2017 Subaru...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
211453 (A62131)
211453 (A62131)
GATOR UTV (A63276)
GATOR UTV (A63276)
Pivot Pipe (A64127)
Pivot Pipe (A64127)
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
