3x20 diverter installation
/ 3x20 diverter installation #1
xkbal
Canada
JD 3720
Has anyone installed the electric diverter in a 3720 cab? The local dealer wants $800 for the install. Seems like quite a lot but if it is a difficult job I'd let them do it. If it's a straight forward kit I might tackle it myself.
I believe the kit says to take of one tire but I think I can get to mine without that as I have 6" axle extensions (best purchase I made, really improved the stability of the tractor) so there is a fair bit of room between the wheel and tractor.
Thanks
/ 3x20 diverter installation #2
Thanks
Great Q, I'm thinking of doing the same...well, I'm thinking of getting the kit, no matter what I'll be doing it myself. Seriously the instructions Deere supplies with all its kits are top of the line.
As far as doing it without removing the tire, I wouldnt reccomend it but anything is possible but it would be WAY easier with the tire off. When I did my rear SCV I removed the tire and with it gone you can easily get to the valve body. I'd rather be sitting on my work stool then laying on a creeper.
/ 3x20 diverter installation #3
Does anyone have the install instructions in PDF? I am also interested in this for my 3720 cab. Thanks.
/ 3x20 diverter installation #4
I'll look forward to your project.
/ 3x20 diverter installation #5
Where did you get your axle extensions? How much were they? I would like to get some for my 4520. Thanks.
My problem is I don't have a shop or concrete pad to work on, for some reason SWMBO insisted on a house before a shop. It seems it would be easier if I could do it without pulling the tire. I can see where you'd have to pull the tire without the extension but the 6" spacer really opens it up. Once I get the kit I'll assess the situation, right now it looks like lots of room to work compared to some of the tight spots in some of the aircraft I've worked on.
By the way how is your power rake? I followed that closely as I want to build one, just can't seem to find the time. Today it looks like I should put the snow blower back on.
They were Unverferth extensions and were $434 CDN each, don't remember what the exchange rate was at the time. My local Deere dealer got them for me and installed them.
/ 3x20 diverter installation #8
LOL, SMBO strikes again, I sorta know how you feel, we built a 1 car attached to the house so her car can park inside... but at least I can pull the car out to do some work in the garage. Working on plans for a "real shop/garage" now.
Good timing on the question, been workin on the final details. Just this past Sunday I officially finished all fab work, the last part was the rubber barrier so I painted everything up and some night this week after work I just need to bolt the barrier & gauge wheels on and then it will be time for its first true job. I'll make a post in the build it yourself section when I get pics of it all assembled.
/ 3x20 diverter installation #9
Please post pictures.. I'm guessing that the kit uses a rocker switch on the fender panel to activate the added SCV's.
However, for those who are wondering about the diverter install - there is the further question of how the 3rd SCV function would be configured for use on the loader - grapple, etc.?
Good stuff...
AKfish
/ 3x20 diverter installation #10
That is correct
Good stuff...
AKfish
What do you mean? The diverter does not affect the 3rd SCV in any way. Nothing changes to the 3rd SCV.
/ 3x20 diverter installation #11
Sorry for not being clear... 3rd function on the FEL. Not the 3rd SCV on the rear of the tractor. (They're related - but only by fluid...)
AKfish
/ 3x20 diverter installation #12
First, I believe tire removal is a must...there is some tight spaces you need to work in. Crowfoot wrenches are needed sometimes as well. You also need a CLEAN place to work...your hydraulic system will be open to the elements during the install.
Below is the diagrams from JDParts...lot's of connections to be made.
/ 3x20 diverter installation #13
I actually got a copy of the instructions, I am looking them over later this morning after I install Power Beyond on my unit.
/ 3x20 diverter installation #14
Can you Scan & Post em?
/ 3x20 diverter installation #15
Dave;It is too large, send me a pm with your email address, so I can send it to you.
/ 3x20 diverter installation #16
I installed the JD hydraulic diverter on my 3320 open station. I don't think you will be able to do it without pulling the fender which, at least on my open station tractor is the least of your worries, not sure the difficulty on the cab tractor. On mine you have to remove the four steel lines that go from the joystick to the two loader scvs and install 12 new steel lines. four from the joystick to the block that changes flow. Then four to the front loader scvs and four lines to the rear which were a little challenging to add with my existing 3rd scv. The clearance between the lines on the diverter block is extremely tight. I am a master automotive tech with tools for nearly anything and I had to install the lines in a sequence so there was enough room to get any kind of wrench, flare, 45 degree, 90 degree, crowfoot.
I ended up buying a set of these after the fact.
315AN, Set, Wrench, Crowfoot Flare Nut, 12-Point (15 pcs.) (1 1/8" to 2")
A couple of hints.
make sure to clean the lines before you install them. My kit was shipped in the foam peanuts and some of the caps were off the ends of the lines so some had chunks of foam in them.
Make sure your work area is super clean.
Buy some low vis. fluid. you will need to add some
I also relocated the toggle to the fender, instructions wanted it next to my 3rd scv lever. I had to extend the harness and route it through the ROPS into the fender. Not a big deal to soldier on new wire and terminals. Not sure about the cab kit.
I also installed a Power Beyond kit which wasn't nearly as challenging as the diverter.
Hope that helps, Once done, install the top and tilt, hook up the box blade and have fun. Power center link is priceless.......
/ 3x20 diverter installation #17
A picture or 5-6 would be a real treat for us junkies...!!! :drool: I'd really like to see where the diverter block was mounted.
Snap-on tools are definitely a "thing of beauty" -- but, it sure took a big chunk out of any money saved by DIY.
AKfish
/ 3x20 diverter installation #18
Wow are they expensive. I think i may get some but they won't be SNAP ON!
/ 3x20 diverter installation #19
Good luck. I couldn't find them anywhere else.... Searched Mac, Matco, S-K, Cornwell, OTC, and numerous Chinese and Taiwanese manufacturers. A normal crowfoot will not do the job. I will try and post some pictures tonight of the install. I have been tied up the last two nights. Never took any during the install just focused on getting it done I guess.
