Amp meter pegging 2615 4WD
/ Amp meter pegging 2615 4WD #1
mjburns
Rail Road Flat, CA
2006 2615 Mahindra
My amp meter briefly pegs all the way to the right when I push in the clutch. Seems to be one point in the travel where it happens, but seems to be working fine otherwise. Is this something I should be concerned about. What are the possible causes?
Thanks
/ Amp meter pegging 2615 4WD #2
Thanks
I would check the wiring around the clutch linkage to see if there's any type of interference with your wiring because that's the only thing that I would think might cause the amp meter to peg. I think you need to be somewhat concerned because more than one tractor has gone up in flames due to an electrical short. You may be shorting something that has a very large fuse in it's circuit and just not enough to blow the fuse, but still might burn the wiring.
/ Amp meter pegging 2615 4WD #3
I was thinking the same thing. Check the wiring where your clutch is. I'd be VERY scared of a electrical issue especially if you park it in your garage/shop.
It sounds like it should be an easy fix!
/ Amp meter pegging 2615 4WD #4
On the same page, check your ground wire from the voltage regulator. If you can get a friend to help you, if no visible problems are evident, you are going to start wiggling some wires while the friend observes the meter. Hope that helps and good luck.
/ Amp meter pegging 2615 4WD #5
Thanks
Tap on the amp meter when working the clutch. Watch to see if the meter does it at different clutch positions. You might have a bad amp meter. Otherwise it would be a hot wire getting grounded when clutching. Is the clutch position pegging the meter when the clutch linkage is engaging a sensor or cutout switch? I am not sure what all safety systems engage and disengage by your clutch. Is the wires to and from your amp meter hot to hold while working the clutch?
hugs, Brandi
/ Amp meter pegging 2615 4WD #6
but choose that "friend" very carefully.
The notion of troubleshooting electrical shorts with one person's head under the hood and another person's foot on the clutch - - is kinda scary~
The sort of "accident" we read about here almost daily.
If I was the one with my head under the hood I would AT LEAST be sure to have every copy of that tractor's key in my pocket.
Anyway, my guess is a wire rubbing up against the clutch linkage, probably chaffed through where it wraps around a sharp edge/corner of metal.
It takes a LOT of wear to abrade through insulation against smooth flat metal, that is why I would be looking at corners and edges first.
Thanks
I thought I'd post that I have since discovered that what I thought was the amp meter turned out to be the temperature gage. Why it pegs briefly when I engage the clutch is still a mystery. But at least I'm not too worried about burning up the wiring.http://www.tractorbynet.com/forums/images/smilies/new/ashamed.gif
