Tractor Logging
   / Tractor Logging #1
Treefarm
I have Timberland in Oregon that I have been logging with a small dozer for the past ten years.
Lately, I have my eye on a DK65 with a Farmi winch, probably the 501.
I would love to hear feedback from anyone that has experience yarding logs with a tractor. I like the dozer but it is too slow on the turn. Often, I collect logs from all over the property and put them on one landing. This means I am somtimes driving 1/2 a mile to get the log. My dozer walks like an old lady. If I had $125k laying around I would buy a new faster dozer but 35k for a new tractor and winch sounds a lot better. Plus the utility of a tractor can't be beat.
What do you think?
   / Tractor Logging #2
I used a Farmi 501 for a few years. Only has winching capabilities, get ready to lug the cable and chain to the logs. Usually has 3-4 sliders so you can winch more than 1 log at a time. You will want a good stout 3PT lift on the tractor. Nice durable unit. I sold mine in favor of a 3PT grapple/winch combo.
   / Tractor Logging #4
I've been using this setup for about 5 years now. Depending on the size of the log I can haul up to 3 of then at a time. It's not a wench so I have to back up to the log to get it lifted to drag, but it works just fine.
I use low range second or third gear to get the log out to a logging road then switch to high range second gear to take them to the landing.
Been using it to clean out beech.
   / Tractor Logging #5
How about a used skidder?
+2
Depending on how many acres you are treating, how often you treat, half mile draws?? I'd be scouting for a used skidder. They are designed and made to haul wood for production. I don't have one, but have used tractor mounted Farmis. They do fine for small lot/part-time cutter, but they are no substitute for a real piece of timber harvesting equipment.
You can pick up a used small to mid-sized skidder around here for $10-20k, use it for a few years and turn it around for the same thing. Just saying. Not to sound negative on the Farmi winches, I have coveted one for years, but I do not have real production in mind. Just putzin' around in my wood lot for a few logs and a bit of firewood. Unless you need the tractor for other purposes and want one versitile piece of equipment for different tasks. A skidder pretty much just skids and pushes, not much more to do than that. So if that's part of your thinking (one piece that multi-tasks), than maybe a tractor is the way to go. It will certainly out skid a dozer, though you will really have to watch the terrain because you'll give up much stability with a tractor. In fact, the tractor is far less stable than a skidder.
   / Tractor Logging #6
I had a DK65, that I used for a number of years, and very happy with its work. I am still using the Farmi JL501 that I had on the dk65, now on a DK40se. I found the smaller tractor is better for my small roadways, and a bit more manuverable. I was so happy with the farmi winches after about 2 years of use, I have started selling them too.
   / Tractor Logging #7
Do you have other uses for the tractor? If you don't, the used skidder idea would be a good thought. If you have other uses, the tractor/winch will do fine. There were a pair of loggers locally that worked full time for 20 years, using a small dozer for hilly ground and a tractor/winch for the bulk of their skidding. They did not get rich, but stayed in business and supported their families with that set-up.
Will
   / Tractor Logging #8
Will
You're much more concise than I......................... ;-)
   / Tractor Logging
I harvest 5-10 loads a year, mostly on the weekends during June. When I clear cut I rent a D5 dozer and get 3 loads a day. Buying a used skidder makes me nervous because I know how hard commercial loggin is on equipment. Something with a warranty puts my mind at ease.
Like many on this forum I am a land owner and take pride in doing the job myself. Plus, I'm only 33 so swinging a saw all day is still fun.
Will I need a 50 Horse plus tractor to handle the yarding? Also, does the Farmi freespool?
   / Tractor Logging #10
The pictures I posted earlier of my skidding equipment shows it hooked to a DK35 hp tractor. It has plenty of power for my hilly farm. It's also not as large which makes it easier to get around in the woods.
2012 Ram 1500 Crew Cab Pickup Truck (A55788)
2012 Ram 1500 Crew...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
UNUSED WOLVERINE JMR-22-8.5G 1R RIPPER (A54757)
UNUSED WOLVERINE...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
