Rear Blade Why doesn't my rear blade cut?
   / Why doesn't my rear blade cut? #11
Does shortening the toplink not cause the boxblade to roll forward? lowering the scarifiers?
   / Why doesn't my rear blade cut? #12
My bad guys. You'all are right - I had it backwards. That's what happens when you sit at your desk and write about your tractor!
:laughing::laughing: We are all guilty of that sometimes:thumbsup:
Thanks for the feedback. I'll see if I can get a good look at the cutting edge this weekend and post some pics. As I had it set up last time I had it on the tractor, the only cutting it did was to scrape the center hump off the drive. Didn't do anything after the hump was removed.
   / Why doesn't my rear blade cut? #14
Cyril:
I use blade I borrowed from a friend - he uses box blade and this just came with his first tractor as a bonus.
Anyway as part of the deal I replaced all the fasteners, most of them were loose and the whole blade was very rickety. I took it apart, new plow bolts etc and also flipped the cutting edge upside down since the top seemed in better shape. It made huge difference, I actually had to relearn how to use since the change.
   / Why doesn't my rear blade cut? #15
Extra weight will help a lot, if the blade will stand the added load. It sounds like you're trying the same job I did last weekend, re-grading my driveway.
The hard-packed gravel and stone surface just bounced the blade along for the most part, the center ridge did get chewed down though.
Some serious weight and a rigid blade will do the job. Road graders have scarifiers for the same reason, they concentrate the weight of the machine on a very small area, thus getting penetration of hard surfaces. A box blade will do a better job IMO, I don't have one either.. yet.
I believe the average rear blade is better suited to leveling loose material, snow removal, or removing high spots.
Chilly
Chilly
The main area I wanted to attack, was where I had a dump truck tailgate spread 10 yards last year. I discovered that I'm not 20 any more and said scr*w this and put the shovel away last year. I regraded that area Saturday with the front bucket in two passes. The rear blade just slid across the top of it when I tried last month, yet it was still soft enough to dig with a square point shovel.
I figured I'ld better post and figure out what I'm doing wrong after looking at pix in another thread and seeing Mtnviewranch post this picture.
   / Why doesn't my rear blade cut? #17
That Woods rear blade, which has hydraulic blade tilt, offset, and angle, weighs in at a whopping 1100 lbs plus. I'd dig too if I weighed that much...
Chilly
Chilly
I'm not sure what my old JD 65 blade weighs, but I'm guessing around 500#. It's built solid so maybe I'll see if I can figure out a way to add about 500# to it and get it up around 1K# and try again. LOL
   / Why doesn't my rear blade cut? #19
I have a used JD 65 (8ft) rear blade which I have only tried to use a couple of times in the few months I've had it. As I have been reading various threads, I have seen rear blades which will roll a full blade of material while being used. Mine pretty much just slides over the surface taking any small humps off and has never got more than three to four inches of material built up in front of the blade.
Here are my questions:
1) How much does a JD 65 blade weigh and how much does weight affect the ability of the blade to cut?
2) My cutting edge is rusty from sitting outside before I got it. Can the cutting edge become dull from this? Would it be advisable to replace the cutting edge with a new one?
3) The few times I have used the blade, I have had it in what I would consider a neutral position (the mounting arm between the 3PH and the blade level). Should I need to extend the top link and roll the blade back increasing the angle of attack on the blade for it to cut well? Would that be considered normal?
TIA for any feedback.
Since questions 1 and 3 have been discussed, I'll take a shot at #2. I haven't noticed much difference as I've used my blade but most have a reversible cutting edge. Flipping it over should give you a fresh cutting edge.
   / Why doesn't my rear blade cut? #20
dcyrilc,
I have a Deere 45 7' blade which is very similar to yours. I don't have high expectations as to what it can do but I have used it with topntilt to cut ditches and move material towards the center to crown the driveways. It really depends on how much use you have for the various implements but doing enough work having a grader/landplane and a boxblade to augument the rearblade helps alot.
CATERPILLAR D4G LGP CRAWLER DOZER (A52707)
CATERPILLAR D4G...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
Utility Trailer (A52377)
Utility Trailer...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
