pole barn concrete slab
/ pole barn concrete slab #21
I'm having trouble locating plastic 3" rebar chairs. the local concrete supplier / brickyard only has 3" in metal, and they are expensive, over $1 each compared to about $.12 for 2" plastic chairs.
Check with hardware store for the plastic chairs. My local Menards has them.
/ pole barn concrete slab #22
Worst case, pick up some of the 1"x8"x16" concrete bricks. Break them into pieces and set the 2" chairs on top of them.
/ pole barn concrete slab #23
The 2" ones would be perfect anyway, you don't really need 3".
pretty much what I was thinking about doing, put something under 2" ones.
don't have menards here, looked online, etc...
I did find one Lowes with a few 2" ones in stock.
thanks!
/ pole barn concrete slab #25
I plan to line the pole barn interior with steel panels. So I'll have interior girts. Can I put use an interior skirt board and pour concrete floor up to that vs pouring concrete between posts up to exterior skirt board before installing interior steel panels.??
/ pole barn concrete slab #26
Go with 2" chairs. don't mess with em, just use them.
/ pole barn concrete slab #27
Watch a few You Tube videos from RR Builders. They install a skirt board both inside and outside the poles and install insulation in the cavity before installing interior metal walls. The slab is poured against the 2 x 8 interior skirt board halfway up thus insulating the slab perimeter.
Back from the dead.
/ pole barn concrete slab #29
Got several posts into this before I realized it was 11 years old. :oops: Zombie thread.
We're doing this same thing this summer in our pole barn. Finally.
Best thing I ever did was add the concrete. Now for electric.
/ pole barn concrete slab #31
Did you do floor heat or electric conduit in floor?
Not me, I still don’t have electric in the barn except for an extension cord.
/ pole barn concrete slab #33
I'm putting a floor in my pole barn this year, also. I'll be putting PEX in for floor heat, but I'm not positive I'll be heating it that way. I can't add it later...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59914)
2018 KAUFMAN 44 FT...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
