Trimmer small engine running poorly
/ Trimmer small engine running poorly #1
DocHeb
Michigan
New Holland TC40D Supersteer
I have a Ryobi weedwacker that uses multiple attachments such as a blower, edger, trimmer, etc. I am having problems with keeping the motor running. It is a 4-stroke engine that will start with full choke and runs about 1/3 speed. If I open the choke about 5%, the engine will run a little faster, but never comes up properly to full speed. If I open the choke just a hair more, the engine dies. I am using fresh gas. I'm not very familiar with small engine repair, so I am looking for suggestions.
Thanks.
/ Trimmer small engine running poorly #2
Chris, since it's a 4-stroke, I think you probably need a carb kit installed with new seals and jets. Methanol in our gas seems to make carb seals and components fail with regularity. I'd take it to a Ryobi authorized shop and let them have a look at it. I love my IDC/Ryobi 2-cycles, but I've never owned one of the 4-cycles. It just sounds to me like you have some restriction in fuel delivery if you have to choke it to make it run. It also might be a pinhole in fuel pump diaphragm as well.
/ Trimmer small engine running poorly #3
Try running some gas with Seafoam or equivalent. Sound like the jets are a little gummy and some form of injector cleaner will usually clear it up in a tank or of gas.
/ Trimmer small engine running poorly #4
a carb kit and new fuel lines will get her purring again, i have troybilt big red version, man i hate that p.o.s, motor seems bullit proof, but the fuel delivery isn't worth a wooding nickel.
i wish they would remove those primer bulbs
A tank of 20% Seafoam didn't help. I can't find a carb kit from Ryobi for this Model 1079 trimmer head. This is a homeowner model that cost ~$150, and the first hour at the Ryobi shop is $75. I think it is designed to be used for 50 hours, then thrown away. Thanks all for your suggestions.
/ Trimmer small engine running poorly #6
Doc you might also check the fuel pickup in the gas tank. They have a filter on the end of the line that when clogged can cause symptoms you describe.
MarkV
Yeah, I was looking at that... I will be out of town for 10 days so I will try switching that out when I get back. Thanks for the reminder.
/ Trimmer small engine running poorly #8
Agreed:) I've gone thru 3 or 4. They are great while they last, but pretty much like a BIC lighter, use and discard
/ Trimmer small engine running poorly #9
Your right chris, theyre disposable. i wasted 75$ on parts for a ryobi blower....never again. no more ryobi for me. ill keep to my huskvarnas and hondas.
my best advice is to save your money and put it towards a husky (make sure its made in sweeden, thats their better line). youll then have a lifetime machine that can be rebuilt if necessary
/ Trimmer small engine running poorly #10
i searched online for a while for you and could only come up with a whole carb for 60 bucks, YIKES! your only a few more bills away from a nice husky
Vibratory Plate Compactor (A64553)
Vibratory Plate...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
2009 IHI IC70-2 CRAWLER CARRIER (A65056)
2009 IHI IC70-2...
BOBCAT 751 SKID STEER (A65053)
BOBCAT 751 SKID...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2018 CHEVROLET IMPALA (A66091)
2018 CHEVROLET...
