Tires Tires, filled or not?
/ Tires, filled or not? #1
lilranch2001
Super Member
Bobcat CT 235
I just bought a new CT235, it has a fel and general purpose tires.
I have been tosing around the idea of having the tires filled with beet juice, but am wondering if I really need it seeing as the BobCat is a lot heavier then most of the other tractors on the market.
Any suggestions? I am going to use it plowing snow, working in the woods and doing landscaping around my place
/ Tires, filled or not? #2
This is from someone who bought his tractor new and did not fill the tires for the first 7 or so years of use. Then when I brought it in for an 800 hour maintenance, I had them fill it with beet juice and kicked myself in the a%$ for not having done is sooner. Better stability, never get tipsy with heavy loader loads, better traction. You'll also do better plowing snow. The ONLY downside is a heavier footprint on the ground. If that's not a problem, there's no reason not to fill. (And the beet juice is non corrosive, environmentally friendly, and weighs as much as calcium chloride, about 11 lbs per gal vs 8 or so for washer fluid)
/ Tires, filled or not? #3
unless you mow grass on soft wet ground,FILL EM,I have 235 also and filled tires will help tractor ride better and if you do any groung engaging work you,ll be glad you did.I used rim saver.
/ Tires, filled or not? #4
Whatever your tractor does best it will do it much better with the tires filled. You really have to try it both ways to appreciate the difference. When you talk of beet juice I assume you are talking about Rimguard.
Thanks for your imput, I will try it without, and then probably go ahead and have them filled
/ Tires, filled or not? #6
I have the industrals filled on my Ct440 and love it compaction isn't as bad as expectaed as long as its dry. For loader work its a must.
/ Tires, filled or not? #7
I had mine filled for several years - right up until my tires froze to the ground (nothing to do with the fill) and I popped the seal on the rims trying to drive off. Lost the fill, of course, and didn't re-fill them.
I've noticed almost no difference as long as I keep weight on the 3ph. None at all in snow, none in loader work. The only place I notice is using a box blade, where I now have to take lighter bites after the ground has been worked a couple of passes and is soft. I also haven't noticed any difference on hills in terms of tippiness, and I'm not particularly hill-shy, either.
/ Tires, filled or not? #8
You notice better traction etc...well worth the extra coins.
/ Tires, filled or not? #9
Don't even consider waiting; most folks feel they're safer with the loaded tires, myself included.
I didnt, I had the rears filled, $180 bucks for rim guard
/ Tires, filled or not? #11
yes, brand name is rimguard but all it's just beet juice. Not sure if they add anything to it.
I just read in my owners manual that you are not supposed to fill the fronts, the tire shop said everyone did when I told them to do the rears only. Did anyone fill the fronts?
/ Tires, filled or not? #13
I wouldn't fill the front tires. Hard on steering components, etc. and provides no advantage.
/ Tires, filled or not? #14
I wouldn't fill the front tires either. My Kubota owners manual says that's a bad thing.
/ Tires, filled or not? #15
I have a Mahindra 3215HST, (about the same size as a CK35) I filled front and rear. I doubt that there is any noticeable wear due to the added weight. It just is not all that much, especially when you consider the extra wear and tear that the FEL adds. I suppose that it might be measurable if you were to work the tractor 8 hours a day, day in and day out. But lets be realistic, how many of us do that? I seriously doubt that it wears anything out even 10% faster, probably just about an immeasurable amount. OK, I'll concede, my tractors front end is going to wear out in 19 years instead of 20.:rolleyes: I'll keep all my tires loaded, the benefits out weigh the negative in my opinion, for my use anyway. ;)
/ Tires, filled or not? #16
Why do you think that there is no advantage to having the fronts filled?
You get better traction, the tire holds a load better and in my opinion, the tractor rides better.
/ Tires, filled or not? #17
I have a Mahindra 6000 4wd and, for what I do, I don't see any reason to have the fronts filled. Mostly mowing, raking, baling, bush hogging on steep slopes, and light loader work. Besides the fact that the manual doesn't recommend it.
Everyone to their own tastes, though.
/ Tires, filled or not? #18
Sellercreek, the owners manual for my 3215 only recommends filling the rears, but then goes on to say that front weight improves steering. I do not have any front end weights. I believe that the front end weights weigh more than the fluid in the tires, so I don't see how this is any more detrimental than having the front end weights on. My 7520 manual says nothing about front or rear tires being loaded. It only says how to and how much.
Does your manual not recommend filling as in it says "do not fill the front tires" or does it just not recommend it. My 7520 manual recommends filling the tires to aid in traction and then if that is not enough to add cast iron wheel weights. It does not say "do not fill the front tires" It basically says to add as much weight as is necessary to get the proper traction for the job.
If you have been happy with how your 6000 performs, then there is no reason to change, but if you have had steering or loading problems, then I suggest that you try loading the fronts. It seems to me that the tractor would be feel and handle better on the slopes with all the tires filled.
But then I have taken the (as much weight as it takes to get the job done) to heart. Beside having all my tires filled, I have as much cast iron as I can reasonably get for the 7520.
Just my opinion ;)
/ Tires, filled or not? #19
Without having noticed where you are located, the seasons here and I think you should fill them yourself with plain water 1st to see how you like it. I say this because its free and there is a chance of weight related drawbacks based on what I have learned on another thread regarding CTs 225,230 etc. They seem to be regarded as underpowered for their weight -- especially if they are HST drive. If the water feels good to you youll know youre good to go with the extra couple hundred pounds beet juice will give you. If not just water the lawn.:)
larry
/ Tires, filled or not? #20
I will say that if you have hills, filling the rear tires adds a lot of stability. I have never filled the fronts but I might just to see if it helps. Unless I was doing a lot of landscaping I see no downside to filling. i leave some good ruts in the fields sometimes when the ground is soft.
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Decorative Turtle Statue (A61569)
Decorative Turtle...
2022 North Star Pressure Washer (A60352)
2022 North Star...
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
LandHonor LHR-SL2T3M 2-Ton Chain Hoist (A60352)
LandHonor...
HYSTER H80XL STRAIGHT MAST FORKLIFT (A62129)
HYSTER H80XL...
