Multiple hydraulic problems JD 4300 HST
/ Multiple hydraulic problems JD 4300 HST #1
roquefortnight
Hi all, I'm a new member and hope someone can help me. I used tractorbynet extensively when I was shopping for my tractor several years ago, and it was a huge help. I ended up getting a John Deere 4300 HST and have been generally happy with it. This was before JD went to the electronic transmission controls.
My hydraulics are quite messed up at the moment. Steering, front end loader, three point hitch and transmission are all not working properly. A little history first: a couple years ago, I snapped my steering cylinder (next to the front axle) by running into a stump. Replaced the cylinder in the field and changed the hydraulic fluid. There were some metal particles in the pickup screen, which I have saved: about a level half-teaspoonful, magnetic, the largest pieces are about a half-inch long, and they appear like little warped pieces of sheet metal. They haven't shown any propensity to rust.
After this, the steering had a tendency to wander, and I'd have to keep turning the steering wheel to go in a straight line, but the rest of the tractor's functions worked fine, and I've since used it for some fairly heavy work for the machine's size, mostly winching/skidding logs with a Tajfun winch and snow removal with a rear PTO blower. The JD has about 650 hours on it, though a fair amount of that time is idling. I'm not sure exactly how long has passed since I replaced the steering cylinder, but just guessing I'll say 100 hours.
A couple days ago, after a heavy snow, I noticed the loader was slow and "notchy" in raising, and it took a few moments after moving the joystick before the loader would respond. The three point hitch then started acting a little slow. Finally, I had a bucket (60") full of snow and found I couldn't raise it at all.
Today, trying to figure out what is wrong, I started the tractor and it would not respond to the hydraulic pedals. No strain or load on the engine, pressing the pedal did nothing. The operator-sensor switch works, and will kill the engine if I try to move the machine by pushing on the pedals without sitting in the seat. After several attempts, I was able to raise the bucket just enough to dump the snow, and I managed to back up the tractor about 20 feet to a more accessible spot, although there was quite a bit of groaning going on (in the transmission, I guess).
Right now I'm trying to figure out what to do. It will be dark before long, and I don't have an indoor space to work on the tractor (and there's a lot of snow outside). I'm trying to decide which is the wisest course: drive to the dealer and get new fluid, filters, etc., and hope that the problem is a clogged pickup screen, or something, or should I have someone from the dealership come out ($). To my uneducated eye, it looks like there are two pumps near the front of the engine I'm guessing one is for the steering and one for the joystick (or whatever it's called), but I guess there must be another pump for the transmission somewhere.
If anybody can offer some advice I would surely appreciate it. We depend on this machine, and there's likely a bit of winter weather yet to come.
I don't know what the forum etiquette is, or if it's ok to duplicate this post in the Hydraulics section of tractorbynet.
/ Multiple hydraulic problems JD 4300 HST #2
First, can I assume you did the obvious and checked to see if your
fluid is full and not cloudy?
Second, when you say you had metal particles in the pickup screen, did
you remove the suction filter from the bottom of the gearcase? A lot
of debris/gunk on it can cause these problems.
Your HST charge pump is one of the two hyd pumps on the front of the
tractor...it shares duty with the PS. Since all of your hydraulics are
not running correctly, my suspicion is that you have caused a severe
restriction in the system (dented hyd hardline underneath, clogged filter,
etc) or the common shaft between your two front pumps has partially
sheared.
/ Multiple hydraulic problems JD 4300 HST #3
I would change the fluid and filters and clean the suction screen. I would suspect there is some debris in it. If the metal from b-4 did not rust it must be aluminum :-(
Thanks, the fluid isn't cloudy and doesn't seem to have any debris in it. The suction screen (it's been a while so my memory is not fresh, but a figure it was about 8" or 10" long and made with a sort of corrugated nylon fabric) is where I found the shavings when I replaced that steering cylinder a couple years ago. I also replaced the spin-on tranny filter. Is there another pickup screen that I missed or don't remember? I don't see any evidence of a dented steel line.
/ Multiple hydraulic problems JD 4300 HST #5
At this point, I suggest doing two things:
Flushing out the hydraulic system altogether. Since you wrote about debris...some of that debris may be restricting the hydraulic flow (at a check valve, perhaps).
The other thing is to check all fittings for tightness. You may be pulling air into the system. I doubt it's a cracked line...if that was the case you should see hydraulic fluid spraying or misting out (and under or on your tractor).
Thanks again. By flushing the system, do you mean with an external hydraulic pump? Is this something that can be rented, or am I better off having the dealer do it? It did occur to me that getting the front end loader off might be difficult if I can't get the hydraulic cylinder to fully retract. Getting the snowblower off the rear will probably be a pain too, if I can't back the tractor up, but at least it can be muscled around if there's no alternative.
/ Multiple hydraulic problems JD 4300 HST #7
You could do it at home, but the dealer would be more convenient (except for the $$$) especially during these cold winter months. If you do send it to the dealer, just leave the loader on. They can use another tractor's hydraulics to remove it.
But it would be better if the loader was off. It might be easier to flush the loader and tractor seperately.
The dealer will be better equiped to bleed any air too (but that's just a matter of cracking a line and bleeding air).
If you do this at home, it'll be advisable to have a hydraulic schematic. Specifically look for check valves (heck, you might even have a bad check valve restricting the hydraulic flow). Also, if you do use another tractor to remove the loader, figure out how to filter the hoses between their tractor and yours. It wouldn't be neighborly to contaminate his hydraulic system.
/ Multiple hydraulic problems JD 4300 HST #8
If the tractor is close to power I'd suggest putting a tarp over it and an electric heater so you can work in semi comfort.
Then drain the HST fluid and pull the screen and filter to see whats there. After that make some decisions.
The transmission has two Non adjustable PRV's just to the right of the filter. The manual will call for a 10,000 psi gauge if you check pressures. There are also plugs for a pressure gauge located there.
The loader joy stick has an adjustable PRV under the right fender.
Do you have a manual?
There are three pumps, one up on the engine for power steering, and two together behind the filter case. One of these is a charge pump and the other is the main pump.
There is a thread from just several days ago here on a JD 4200 on which the loader would not work.
http://www.tractorbynet.com/forums/hydraulics/164131-john-deere-4200-loader-slow-4.html#post1892726
/ Multiple hydraulic problems JD 4300 HST #9
I would check te rubber "manifold" on the hydraulic pump. The suction line hooks up to this manifold. I have seen some of these develop a crack that will suck air. It is high enough that oil won't run out when not running. It is #2 in the diagram. Also check hose #8 for tight clamps.
/ Multiple hydraulic problems JD 4300 HST #10
How warm is it where the tractor is at? Is it possible that there could be condensation freezing in the lines, FEL control valve?
Really appreciate all the helpful replies! I think I'm going to drain the fluid tomorrow morning, check for possible loose connections, and either go to the dealer for replacement filters and fluids or if I don't find anything obvious I'll call and see what they say.
When I saw that "manifold" I thought the solution was at hand: the rubber had softened, collapsed and was restricting flow. But looking more closely it seems to be an injection molded plastic part that happens to look like it collapsed!
I did read that 4200 thread before I posted with my question. I'll see if I can find one of these high-pressure gauges and put together an assembly to test with, but I suspect (hope) I'll have a clearer idea of what's going on by day's end.
I'll keep checking this thread, and will give a progress update when I have something to go on. Many thanks.
Condensation is another possibility. It probably got up to 34 today, which is about as warm as it's been in a while. But since the problem worsened only after a few hours of work, I doubt that icing is the problem. It's a good thought, though, especially since these hydraulic lines go every which way and could lose enough heat to prevent thawing. The weather's supposed to be pretty mild the next few days, which is good for some things (not freezing me or the tractor too bad), but introduces its own misery as compensation (wet snow sticks to everything, gloves get soaked, etc).
/ Multiple hydraulic problems JD 4300 HST #13
/ Multiple hydraulic problems JD 4300 HST #14
Agreed. Fluid will look "foamy" while the machine is running.
This is definitely a part of the problem. The part is rubber, not plastic as I had guessed, and it is collapsing. I don't know why I didn't see that before. Thanks for the suggestion.
/ Multiple hydraulic problems JD 4300 HST #16
Surely hope Kenny's advice:thumbsup: will solve the problem. :D
After all that, a fluid and filter change and cleaning the pickup screen restored all my hydraulic functions. Even the steering seemed better, though I'd be surprised if that problem is fixed, since I had already done the above when that problem developed. Anyway, I know more about my machine's hydraulics and will remember the other suggestions should anything similar happen again. I think I'm also going to keep a complete transmission service kit handy in case this ever happens again.
Two other pieces of metal came out of the main transmission drain when I opened it, similar to the others I had saved. The pickup screen was cruddy, but not with big chunks of anything. Looked more like lint to me (maybe metal "lint"). I washed it in kerosene and scrubbed it with a toothbrush and blew it with compressed air, but I couldn't get it as clean as I would have liked. If that part isn't too expensive I might get another to have on hand as well. The guy at the dealership didn't know what the metal pieces could be from, but said perhaps they were fragments of a servo that was failing. I've got something else to research now, as I don't even know what a servo is. I also found out they've got a discount on parts and labor, and free trucking for most of this month. I'm overdue for my first engine valve clearance check, and while I've done such things on cars and motorcycles I don't have the specs or procedures for this job. Has anyone on this forum done it?
I also have a leak in one of my front spindle assemblies (I think that's what it's called). Don't know what's involved in that either: any suggestions?
Of course I'm totally happy with how this has worked out (knock on wood). It was a great day for working outside: neither too warm and sloppy nor too cold, and my wife was here to take the full one-gallon buckets (the biggest container I can get under the drain hole) while I held my thumb over it. Making the job a lot easier: it's about seven gallons of fluid, as you all must know.
I'm glad I posted my question here, and sincerely thank those who offered advice.
I noticed that I get logged out pretty quickly and have to re-log in. (Learned to copy my comments and save them pretty fast) Is this normal for TBN, or is it my browser settings?
/ Multiple hydraulic problems JD 4300 HST #18
Good Show:thumbsup:
Think about buying the technical manual.
/ Multiple hydraulic problems JD 4300 HST #19
Well to late now...But if you had wrote this before I would have told you that the suction screen was blocked for sure!
Is the material removed definitely metal? Could it be friction material (like from a clutch)?
I am not sure what he was referring to either by the term "servo"
/ Multiple hydraulic problems JD 4300 HST #20
Are you checking the "remember me" box? Will your browser accept cookies?
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2013 Ford F-150 Ext. Cab Pickup Truck (A61573)
2013 Ford F-150...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
