Quick Hitches Harbor Freight Quick Hitch Adapter
/ Harbor Freight Quick Hitch Adapter #2
They make two different sizes. I don't remember the exact dimensions but the narrow ones around 26-1/2" wide the wide one's around 27-1/2" wide.
M.D.
/ Harbor Freight Quick Hitch Adapter #3
Here is a link to the ASAE standard that the QH's follow: ASAE
More often than not, it's the measurement from the lower pins to the top pins that is that problem.
M.D.
Sorry should have said more. The adapter that mounts on top of the HF quick hitch. It allows for a greater range of implements that will work on quick hitch. I think the part number is 29309 and it costs around 10 bucks. I just need the opening between the tabs that attach to the quick hitch.
/ Harbor Freight Quick Hitch Adapter #5
I have a HF quickhitch and love it. What I hate are the few implements that claim to meet the standard but don't. Vertical distance has never been a problem, but the horizontal distance between the bottom hooks is a pain. Once you get a hitch, be sure to shop with a tape measure in your hand to make sure you don't end up with a non-standard "standard" 3-point implement.
Good luck!
/ Harbor Freight Quick Hitch Adapter #6
I have the HF hitch, and have seen the Landpride. I believe it will fit. Landpride does make an add-on of their own, but it simply two metal bars with a hole in each end of each bar. That is something which could be easily made from scrap metal.
They call it a floating top link assembly.
http://www.landpride.com/manuals/man_qh.html
/ Harbor Freight Quick Hitch Adapter #8
Here it is. it's 1 and quarter wide. On the inside and its 1 and seven eights on the outside. You need the outside dimension, not inside. The HF adapter goes on outside on the QH. I am not sure If you trying to using the otherway around.
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2022 FREIGHTLINER...
Giyi Forklift Telescopic Boom (A64912)
Giyi Forklift...
2013 Lincoln MKX SUV (A66738)
2013 Lincoln MKX...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
2024 Land Pride...
