PALLET FORKS FOR 300CX
/ PALLET FORKS FOR 300CX #21
I made mine from used parts from a Cat dealer. The tabs with holes are for mounting my snow plow. The forks stay on the tractor more than the bucket.
Dan
/ PALLET FORKS FOR 300CX #22
I would be careful with these, as I would assume the bucket holders will stick out past the forks and eventually you will break it.
These forks do not clamp on the front of any bucket. From my experience, those clamp on forks really aren't good cause they might bend your bucket.
The Construction Attachments forks go directly to the quick attach and are made specifically the John Deere quick attach. Sounded like you thought that the hooks could somehow attach to the top of a bucket.
/ PALLET FORKS FOR 300CX #23
See my post, #10
http://www.tractorbynet.com/forums/attachments/125784-need-set-forks.html#post1449574
hi fellows, many thanks for all who took the time to give me all that helpful info concerning a set of pallet forks for a 300cx loader on a 3520. cheers, bud
/ PALLET FORKS FOR 300CX #25
Got a welder? Make your own;)
/ PALLET FORKS FOR 300CX #26
/ PALLET FORKS FOR 300CX #27
Ok, I haven't tried one of those spades on mine, but I have dug small stumps out with them pushed close together. Mine are not the compact ones, so I am not recommending anything as I don't know how those will perform.
newtothegarden,
Somehow we got crossed up. Double Click on the picture and take a look at the red circle. I am sure the bucket holder ear will get waffled sooner or later and that is what turned me away from the Construction Attachments forks.
/ PALLET FORKS FOR 300CX #28
Dan
Dan, If you have more spare parts I'd like one like yours... Nice Job!
/ PALLET FORKS FOR 300CX #29
Just a note - the good quality clamp-on forks will not bend your bucket. I have a heavy duty set of PaynesForks and they are awesome - easy to put on and off. If you need a set of forks for heavy, frequent use, then you probably want a quick-attach set, not clamp-ons. I use mine for moving round bales to the pastures and unloading an occasional truck. They work perfectly - and they are less than half the cost.
/ PALLET FORKS FOR 300CX #30
Agree with OtterBrook, the PaynesForks are top quality and get the job done. I can put them on in less than a minute and they are good to go. These forks will NOT bend the bucket. I have a 3720 with 300CX and use the forks to stack my seasonal attachments on pallet racks. A great investment.
/ PALLET FORKS FOR 300CX #32
KennyD; i had a welder and got rid of it.
WOW, Don't think I've ever heard that statement before with out something like "to get another one" following it :)
/ PALLET FORKS FOR 300CX #34
I just did not need to use it, so I went out and got me a 3520 CAB unit to cut my grass! make up for it - MAN CARD re certified:D. But since then, I have had some opportunities where I could have used it since I got rid of it:mad:
/ PALLET FORKS FOR 300CX #35
Followed by "and turned in my man card":p
Ouch, lucky for me it is the tractor/loader/dirtscoop/MMM/RBM, etc on this forum that makes the man, not just the welder:D
/ PALLET FORKS FOR 300CX #36
I just did not need to use it, so I went out and got me a 3520 CAB unit to cut my grass! make up for it - MAN CARD re certified:D. But since then, I have had some opportunities where I cuold have used it since I got rid of it:mad:
And here I thought a welder was a prerequisite to buying a tractor. At least that is what I told the wife so many years ago.:D
/ PALLET FORKS FOR 300CX #37
Well now that you mention it, I got the welder before I got my first CUT, so, ..etc Maybe you are right:laughing:!
Now since the snow season is over, I guess to make up for it, i will need to get that Aerator I have been considering!
/ PALLET FORKS FOR 300CX #38
I built my own quick attach forks with welded brackets right to the loader bucket. No need to remove the bucket just drive in curl bucket and go! Very nice indeed. I can make brackets for anyone interested and give you details as to how they should be welded on. If interested send me a note.
while you are at it check out our website for all your fabrication needs. SLH Metals: materials, fabrication and welding services - Corunna, Michigan
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2015 Kubota SVL 75-2 (A64126)
2015 Kubota SVL...
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
