barberry to remove
/ barberry to remove #1
First one
Gold Member
Eastbrook, ME.
08' Kubota L3240 HST /cab
The place that i work (Maine) is running away with barberry . The owners want it removed ,all of it :eek::eek:Each field has it all along the sides and into the woods( old farm land)We thought that maybe by putting chain(choker) around the bases of the **** we could pull them out with the tractor to try and get all the roots we can. We have used chain saws ,weedwackers with the blades, but without spraying with a weed killer(Can't use ) I know they'll just come back twice as much:mad::mad:
Has anyone got any other ways of removing this stuff?
Scott
/ barberry to remove #2
I've mowed many acres of barberry BUT it was always followed up with herbicide. Maybe repeated mowing will kill it, every month?? Or grub the entire area. I think it will be tough to get rid of without chemical treatment.
/ barberry to remove #3
I believe that persistent mowing will keep it in check. In non-mowable areas, chemical treatment is your most viable solution.
Mike
/ barberry to remove #4
Eastbrook Maine? Molasses Pond?
My friend has a cottage up there that we use almost every 2 years
great spot.
Barbary ,cut it the flush in late summer, then spray the top with
Roundup, the plants all store sugar in the roots in the fall the roundup goes
right to the roots and kill it good, the only way, some goats like it.
Mike In Colebrook CT
great spot.
I'm just a couple of miles from Molasses.
I wish we could spray Roundup on them ,but they don't approve of it . Hard chance of getting rid of them ,without spraying, and some of the areas you can't get a mower into Goats? I think the coyotes would give them a run for there money,They've been **** on the deer!!
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
KUBOTA TE6583T - 6 BASKET HAY TEDDER (A64278)
KUBOTA TE6583T - 6...
Deer Staute (A64557)
2017 HYSTER H60FT STRAGHIT MAST FORKLIFT (A63276)
2017 HYSTER H60FT...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
