Check your well pressure tank
/ Check your well pressure tank #1
zzvyb6
Super Member
michigan
jd 1070
To make a short story long, a year or so ago, I replaced the pressure dial gauge on my well because of a cracked glass. No big deal, just shut well off, run out the pressure, replaced gauge, power up pump. At that time there was quite a surge of blackish water after I repressurized it. Last week I wanted to replace the whole house filter sump (holds the cartridge) with a clear one just to see the filter condition better. Ordered new filter, get a housing + sump. New clear sump has different thread than old one, need to replace entire filter housing. In the process of tightening things up, a drip developed at the union where the well pressure tank is connected. When wrenching it up to stop the drip, the leak turned into a stream. Guess what? The union coupling was all corroded and rotted away: replaced union. With the tank now off the line, I checked the pressure: zero ! Its supposes to be 2 psi lower than the well's low end pressure cutoff (my case 30 psi). Threw air into the Schraeder valve: Hissing at the water line = ruptured diaphragm. Oops. Now I hadn't noticed any remarkable pump short cycling, but the web search indicated the bad tank leads to reduced well pump life and higher electrical usage. Replaced tank and pressure regulator. All systems: go. Great.
Now this tank is a major brand, was about 5 years old and looked brand new (beautiful blue paint condition. But the thing was shot. New tank came with advertized pressure, I increased it to the 2 psi less than low end pressure and things are back to design intent.
If you have a well pressure tank, its snowing too hard to have any fun outside and you have nothing better to do, check your tank by running the water pressure to zero and see if there is any residual pressure in the tank. Use a tire pressure gauge. Should be over 25 psi. If so, fine, if not, save some money and get a replacement.
/ Check your well pressure tank #2
Thanks for the heads up, I have a shallow well pressure tank/pump it's built togeather as one unit and sits above ground, so atleast it's easy to work on!
/ Check your well pressure tank #3
It sounds like you have manganese or iron bacteria in your well, this will destroy the bladder in a very short time. I had the same problem at my cottage; the tank was only a few years old but it was short cycling. When I disconnected it from the piping the most incredible black water ran across the basement floor. I have to shock the well with chlorine to keep it under control.
/ Check your well pressure tank #4
Before you put bleach in the well, put a half teaspoon in a clear glass of the water and stir. it may react to the manganese/Iron in the water and turn the water a coffee color..... :( The bacteria don't seem to harm you. We put in a UV light instead.
/ Check your well pressure tank #5
Heh. After a fire in the laundry set off the fire sprinklers in the jail, we found a lot of them jammed with small gravel. Solution. Pull the sprinkler and put an inmate on a step ladder (!!!) with a bucket to catch the stuff and appply the pressure. Blew bucket, inmate and ladder across the cell. Total black crap and stunk like a sewer. Had to scrub all walls and repaint. We used a more sane method on the rest of the sprinklers. "we" as in I was only the control room operator.
Harry K
/ Check your well pressure tank #6
I have done the same thing using a UV lamp and multiple filters, haven't had a problem in the past 4 years.
/ Check your well pressure tank #7
You might try switching to a regular tank with no bladder. It might help. Of course, you'll have to add air once or twice a year as needed.
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
CATERILLAR 299D2 SKID STEER (A64279)
CATERILLAR 299D2...
2019 JCB 457 (A60462)
211453 (A62131)
211453 (A62131)
RoGator RG1100C (A63688)
RoGator RG1100C...
