How many "TnT" owners
/ How many "TnT" owners #121
Thanks Rob! My Surplus Center top-link cylinder is the same one CCM sells, and the check valve uses BSPP ports. I can easily get BSPP to JIC fittings locally. I will keep CCM in mind should I get around to the side-link.
So many projects, so little time and MONEY!
Don't forget that the hard line (tube) is also metric for those compression fittings.
That allows you to get the spacing between ports correctly. Good luck with your project. Hope some of those old threads help a bit?
/ How many "TnT" owners #122
They help a lot Rob!
