Towing with a chevy 1/2 ton
   / Towing with a chevy 1/2 ton #1
daveandlo
Lucedale,MS
JD 6230
I have a 2009 1/2 ton Chevy 4x4 crew cab with the 6.2 engine. It has the 3.73 gears, 6 speed auto trans, and factory brake control. Also has the max trl pkg which consists of a 9.5 rear axle. Would I be hurting towing 10500#?
   / Towing with a chevy 1/2 ton #2
Are you sure it has 3.73 gears? My book shows only 3.42 gears with the 6.2 and the 6 speed auto. I am assuming your truck is 4x4 but it shows a max tow rating of 9,300# for the Crew Cab Short Bed 4x4 with the 6.2L and 3.42's. If its 2 wheel drive the same truck is 9,600# so there is a little gain.
I would say no but do as you want. You are over by quite a bit here.
The big issue I hear with the 6 speed GM tranny and towing is it hunts for gears. Its really not a 6 speed but a 4 speed with 2 over drives. Guys I know with them like the the 4 speed behind the 6.0 better for towing but say the 6 speed is a better non towing tranny.
Chris
   / Towing with a chevy 1/2 ton #3
Do you mean a 6.0 engine? Is the 9.5 in reference to the ring gear? What does your manual say in regards to towing capacity?
   / Towing with a chevy 1/2 ton #4
Well wait. I do now see a listing for a 2 wheel drive Crew Cab Short Bed 6.2L with 3.73 gears. It looks like the 3.73 gears are only available on 2 wheel drive trucks, not 4 wheel drive trucks according to my book. So if you have this the max tow rating is 10,600# so if that is what you have I would say yes, tow it.
Chris
I ordered the truck with 6.2 engine and the 3.73 gears.
   / Towing with a chevy 1/2 ton #6
I thought 6.0 was the largest engine for a 1/2 ton. Guess not.
   / Towing with a chevy 1/2 ton #7
I would check the build sheet but my book could be wrong. I am a trailer dealer and it list all trucks 2009 to 1989.
If you do have a 4x4 with 3.73 gears I would guess the tow rating would be 10,200# since its listed 10,600# for a 2 wheel drive and they show a 400# penalty for 4x4 trucks with other gear ratios. Not too far off of your 10,500# trailer. I would go for it.
The 6.0 is on the way out to answer Fire Fighters question and now they use a 6.2.
Chris
   / Towing with a chevy 1/2 ton #8
I have not been able to find in any of my literature the 6.2L being spec'd with the 3.73. This must be a new or running change, as the 6.2L was not the selectable engine with the max trailer pack; it was the 6.0
John M
   / Towing with a chevy 1/2 ton #10
I really think he may have ordered the 3.73 but he has a 3.42 gear. I went to Chevy's site but it sucks. I could not find a listing for a 3.73 gear with the 6.2 in a 1500.
I could be wrong though. The site is horrible compared to all the other manufactures.
Chris
2023 Bobcat E32i Mini Excavator (A57453)
2023 Bobcat E32i...
2014 Grove TMS700E 60 Ton 4 Section Quad Axle Crane Truck (A60460)
2014 Grove TMS700E...
2013 EZ-GO RXV Golf Cart (A57453)
2013 EZ-GO RXV...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Air Compressor (A57454)
Air Compressor...
2015 Peterbilt National NBT40 Crane Truck (A60460)
2015 Peterbilt...
