Towing with a chevy 1/2 ton
   / Towing with a chevy 1/2 ton #1
daveandlo
Lucedale,MS
JD 6230
I have a 2009 1/2 ton Chevy 4x4 crew cab with the 6.2 engine. It has the 3.73 gears, 6 speed auto trans, and factory brake control. Also has the max trl pkg which consists of a 9.5 rear axle. Would I be hurting towing 10500#?
   / Towing with a chevy 1/2 ton #2
Are you sure it has 3.73 gears? My book shows only 3.42 gears with the 6.2 and the 6 speed auto. I am assuming your truck is 4x4 but it shows a max tow rating of 9,300# for the Crew Cab Short Bed 4x4 with the 6.2L and 3.42's. If its 2 wheel drive the same truck is 9,600# so there is a little gain.
I would say no but do as you want. You are over by quite a bit here.
The big issue I hear with the 6 speed GM tranny and towing is it hunts for gears. Its really not a 6 speed but a 4 speed with 2 over drives. Guys I know with them like the the 4 speed behind the 6.0 better for towing but say the 6 speed is a better non towing tranny.
Chris
   / Towing with a chevy 1/2 ton #3
Do you mean a 6.0 engine? Is the 9.5 in reference to the ring gear? What does your manual say in regards to towing capacity?
   / Towing with a chevy 1/2 ton #4
Well wait. I do now see a listing for a 2 wheel drive Crew Cab Short Bed 6.2L with 3.73 gears. It looks like the 3.73 gears are only available on 2 wheel drive trucks, not 4 wheel drive trucks according to my book. So if you have this the max tow rating is 10,600# so if that is what you have I would say yes, tow it.
Chris
I ordered the truck with 6.2 engine and the 3.73 gears.
   / Towing with a chevy 1/2 ton #6
I thought 6.0 was the largest engine for a 1/2 ton. Guess not.
   / Towing with a chevy 1/2 ton #7
I would check the build sheet but my book could be wrong. I am a trailer dealer and it list all trucks 2009 to 1989.
If you do have a 4x4 with 3.73 gears I would guess the tow rating would be 10,200# since its listed 10,600# for a 2 wheel drive and they show a 400# penalty for 4x4 trucks with other gear ratios. Not too far off of your 10,500# trailer. I would go for it.
The 6.0 is on the way out to answer Fire Fighters question and now they use a 6.2.
Chris
   / Towing with a chevy 1/2 ton #8
I have not been able to find in any of my literature the 6.2L being spec'd with the 3.73. This must be a new or running change, as the 6.2L was not the selectable engine with the max trailer pack; it was the 6.0
John M
   / Towing with a chevy 1/2 ton #10
I really think he may have ordered the 3.73 but he has a 3.42 gear. I went to Chevy's site but it sucks. I could not find a listing for a 3.73 gear with the 6.2 in a 1500.
I could be wrong though. The site is horrible compared to all the other manufactures.
Chris
toro turf sweeper (A50324)
toro turf sweeper...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
