Finally Building my Backhoe
/ Finally Building my Backhoe
...I would run the hoses on the out side. If you have any leaks they will be easy to find.
That's a good point. I'm glad you brought it up. I realized that I'm looking for reasons to run the lines on the outside since it will be easier to build that way. I had been thinking that the right thing to do is to run them inside to protect the hoses.
Now that you brought up a reason to run them on the outside, I'm sold.
/ Finally Building my Backhoe #62
Much easier to change if needed also.
I need to post a follow up to the issue with the wrong drill bit from Enco. The replacement bit arrived yesterday. It was the right size, and I was pleased with how quickly they got it to me.
The project is going to be on hold for a little while now. We just dug a big hole in the front yard for a walk-out basement and a porch remodel. For the first time in my life, my wife was as excited to see a piece of diesel machinery as I was. :)
I'm running ragged trying to keep up with my full time job and still coordinate all of the subcontractors, permits, inspections, etc. The backhoe is something that can wait, and so it will.
/ Finally Building my Backhoe #64
OK, but make sure to take lots of pix and keep us informed.
Oh, and give us a link to watch the progress on the hole.
I have to celebrate the small steps.
I snuck off for an hour tonight and welded up the skeleton of the boom. I'm going weld plates on the side of the boom accross both seams later, so I ground the welds down to allow the side plates to mount flush.
/ Finally Building my Backhoe #67
I hate grinding welds; but sometimes it has to be done. Keep the pictures coming as progress is made.
/ Finally Building my Backhoe #68
I agree one of my least favorite things to do, counter productive.. :)
I kept wondering if I could have minimized the grinding if I were a better welder. I chamfered the joint good and deep and I turned my amperage up a click, but I still had protrusion above the surface. That said, I had to grind less that I would have had to do a few years ago when I had started welding.
/ Finally Building my Backhoe #70
What welding rod are you using for this project. I followed your original thread on the planning and I will be following this build. It is slowly coming together.
I have saved a bunch of links for tools, parts and material suppliers. That is a plus for me.
I'm using 1/8" 6011 rod. I'm running it on DC+ at about 90 amps.
Per the PM request of a few other members, I'm attaching a .zip file with two partial sketches of the backhoe plan. I've redrawn various parts of the backhoe multiple times as acquired materials or got new ideas about the plan. As a result I don't have any single sketch that covers the whole plan. These two that are attached will give a good idea, though.
/ Finally Building my Backhoe #72
Seems to me that you should be welding at 125 amps? This will give you much better penetration and get that bead to lay down more (less grinding). Also, you might try running them on AC (it believe they are intended for AC or DC reverse polarity). You must be experiencing a lot of stuck rods?
I tried to open your zip but it gives an error.
It sure does. I tried opening it up here at work and got an error. It was my first attempt at creating a .zip file. Apparently I have more to learn. I'll have to try it again when I get home where the files are, and I'll post back when I've fixed the file.
P.S. Thanks for the advice on the welding.
Try this file...
If it doesn't work I'll be seeking technical advice on how to use Winzip 14
/ Finally Building my Backhoe #75
Better seek help as it did not work for me. Got an error window.
BTW, I was welding today and tried 6011 at 90 amps. Seemed a bit too cool for me. I went back to my normal 105 and it is much better for me. Will try the 125 suggested next and see what I get.
/ Finally Building my Backhoe #76
Was able to open the zip files and use Google Sketch up to view the files.
Nice work.
I've not been able to generate that much detail using Sketch up. I need to learn how to do it.
Bravo!
I'm no welding guru, so someone else's advice is likely better. The little chart on the side of my welder said to use 85 amps for 1/8" rod. That's all I had to go on.
Nice work.
Bravo!
What program do you have to open zip files? I wonder if that's part of the problem why some are getting errors and some are not.
As for detail in sketchup, I've found it very handy to make groups and then open the group to edit it. I.e. if I want a square tube, I'll make a square and then make that square into a group. I'll open the group, and then pull the square into a tube. For me sketchup has been a super useful tool. There are a lot of design flaws that I discovered in sketchup that I never would have found with my previous pencil and paper sketching methods. 3D is very nice to have.
/ Finally Building my Backhoe #78
Iplayfarmer,
I would say 90 Amp for the 1/8 6011 is a bit on the cool side but it is within the recommended range. Range being 75-120 or so for that rod. It depends what is the thickness of the material you are welding. Since you are using 1/4 tubing I would say you could crank that puppy up to about 100-110 Amps. You will get better penetration and smoother welds (possibly).
You might want to give E7018 rods a try. They weld very smooth and the end result is stronger if used properly.
www.hobartwelders.com/products/electrodes-wire/electrode-chart
/ Finally Building my Backhoe #79
I've never been able to make zip files work right here. The most reliable method I've found is to change the file extension to .txt with instructions to change it back to what it was.
The box of welding rods should have the amperage range printed on it. I like the hot end of the scale.
Tried it. My files are bigger than the 200 KB allowed. I'm going to try it with a .pdf extension. If I crash TBN and cause an end to the free world as we know it, I'm sorry. Mods please let me off with just a warning.
Right click the file and click "Save target as..." Save the files to somewhere on your computer. Change the file name from .pdf to .skp. Good luck everyone. I hope it works.
Alternatively, I think the problem may be that the files require a winzip program that is not on the computers that can't open the files. I made the files in WinZip 14. I think there are free unzip programs that will open the files. If anyone knows of a good free unzipper program please post it.
Moderators: Is there a chance that we could change the forum to allow attaching .skp files??? With as many of us using sketchup, I'm sure it would be used regularly.
When all else fails, read the directions.
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 Peterbilt 579...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2025 Kubota L4060D 42HP 4WD Utility Loader Tractor (A64553)
2025 Kubota L4060D...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A64194)
1995 Khronert 307...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
