Snowblower Snowblower throwing improvements ????
/ Snowblower throwing improvements ???? #1
doxford jim
British Columbia, Canada
1959 MF-65 sold, 2007 Jinma 554 diesel.
Hi Guys,
I have been doing some thinking on improving the snow throwing capapbilities of the snow blower - especially older ones.
I am looking at two areas here - have previously talked on repairing impeller blade tips.
What i am looking at this time is improving passage throught the shute when impeller pushes the snow. Also, impeller casing surfacing.
Had anyone tried using a plastic coating similar to what is used in pickup beds, to line the shute? I would think a sprayed on coating would improve the movement of the snow, if the surface was smooth - nothing for the snow to latch onto !
Similarly, has anyone tried coating the inside of the fan/impeller casing with same material, to try and get improvement there. Possibly a coating of fibreglass resin that has been gelcoated (might work on the shute as well), as this gets to be very slippery when wet. Also would protect the metal against abrasion and corrosion.
Any thoughts on this - there has to be ways of improving older snowblower at a reasonable cost.
All comments welcome - the more ideas the better. Everyone has a different viewpoint, therefore more ideas come into play.
Thanks
Jim
/ Snowblower throwing improvements ???? #2
Might just a good coat of enamel paint be one good possibility?
Anything similar to what is sprayed in pickup beds, seems would be non-slippery - and not slippery like you are looking for in the snowblower.
I always figured older snowblowers were tossed because of rusted out chutes or bad engines. Hadn't thought of a problem with chutes hindering snow throwing.
/ Snowblower throwing improvements ???? #3
I would imagine than any coating on the impeller and chute would wear pretty quickly.
Some machines have a liner in the chute made of plastic, the same I believe as what it used on snowplow blades.
/ Snowblower throwing improvements ???? #4
There is a slippery paint made for agricultural applications like chutes etc. It has been talked about on here before but I do not remember for what:eek:. It seemed to me that it might have been on the same topic:eek:
I think the truck liner stuff would not work -- epoxy gloss enamel would be better. Snow is not that abrasive so it should not wear down a lining too quickly.
/ Snowblower throwing improvements ???? #5
The chute on my blower is lined with a white plastic sheet. Not sure what it is but the snow (wet or dry) does not stick to it.
Studor,
Thanks for the tip. I went and googled "slippery paint" and came up with a manufacturer out of NY - don't know if they sell to canada or have a dealer here (enquiry email sent).
Here is the link I came up with:
Ecological Coatings - Anti-Graffiti And Non-Stick Coatings And Paints
Their product looks to be exactly what would work. Worth asking a few questions to find this out.
Thanks
Jim - I will report on the enquiry re Canadian sellers.
/ Snowblower throwing improvements ???? #9
Jim, I mentioned this in another post recently so you may allready know. I had an old Erskine pull behind type blower where the drum finally rusted thru. I made a temporary repair by lining the drum with a hard vinyl semi trailer mud flap. It stood up very well, but I was amazed more at how it improved the distance it would cast the snow. Since then, I have made this modification to two other blowers I've had, an old Hanson, and now my current Lorenz. Expect to pay about $ 25-30 for one flap plus a bunch of 8-32 or similar machine screws and nuts. This material is easy to cut and form, especially if it's at room temperature. Yes, it's more work than applying the non-stick paints, but it's not affected by stone chips or rust. mine has been through many winters and still looks like new. I line both the chute and drum. Just an idea for you to ponder
Hi Guys,
Thanks for your suggestions - all offer some improvement.
I have been dooing some checking on the Canadian Home Hardware website and found a 2 part epoxy enamel made for refinishing bath tubs etc. (part number 1710-367). This looks like it might just do the trick and it comes in two convenient sizes 500ml and 1 litre, for $32.99 and $39.99.
The prices are ok and being a two part epoxy, should make it tough as well as hard. So hopefully it won't be too inclined to chip readily. The only con is the surface prep - which you would probably have for any coating anyway.
I also like the idea of the white plastic liner for the chutes - or any other colour for that matter.
Hmmm, seems there are a number of different approaches that can be made for a reasonable price.
Whatever I decide to do, won't get done until this coming summer since winter is not over yet. However the above certainly gives me some interesting ideas.
Thanks one and all for your thoughts - very much appreciated.
Cheers
Jim
/ Snowblower throwing improvements ???? #12
Something cheaper than a mudflap that might work very well to line a chute would be a plastic snow slider sheet (Google "roll up snow tobbogan") like this one:
Amazon.com: Pelican Snow Flite 54 Roll up Plastic Sled - 54 x 18: Sports & Outdoors
These are incredibly tough and very slippery. They usually come in lengths of about 36", 48" or 54" and 18" wide. So far, I have only used them for snow sliding/sledding, but they definitely won't stick to snow (and will blow away at the slightest excuse!).
BOB
John Deere 7320 (A62180)
John Deere 7320...
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
Paladin 544K 416 IC 105in. Dual Cylinder Hydraulic Loader Attachment (A61567)
Paladin 544K 416...
