Chains Tire Chains on M59
/ Tire Chains on M59 #1
BobSWcolorado
I have a M59 with a 7.5' skid steer type hydraulic angle snow blade on the front end loader. On the steeper parts of my 1/2 mile long driveway it slides badly, especially if it is at all icy.
The owners manual and the local dealer both say you cannot chain up the front wheels, they say it will ruin the front drive. Does anyone have any experience or knowledge with this on a M59?
There does not appear to be room for chains on the rear without the $500+ Kubota rear wheel spacers. There is only about 1" between factory R4 tires and the fenders/fender bolts. Low profile cable type tire chains might fit. Does any one have any experience using chains on the rear of a M59 without the spacer kit?
I would appreciate hearing about any related experinces. Thanks much.
/ Tire Chains on M59 #2
I won't say for the M 59 specifically, however, I will say for the last 50-60 years, around this AO, that all contractors and local, county and state highway dept, use St Pierre "rollers" on the fronts only. I have never heard and I have asked others and they have never once heard of ruining a front end component using the St Pierre roller system,, As stated, the chains are constantly rolling around the tire tread and are actually loose,, They work awesome and you get much more power with the front drive axle pulling rather than pushing from the rear,,,, I've run thousands of hours, over more than 30 years of winters on JD 710 TLB's with this system, and ocassionally the JD 544 and 744;s also,,
/ Tire Chains on M59 #3
Bob, that sounds like a nice rig. I didn't know that bit about chains on our M59s....and I must have missed the bit in the manual about not chaining up the front tires because I bought chains for mine.
Even though it would be possible, I confess that I haven't looked at the strengths of the various front drive components. Reason is real basic: I simply don't believe that a M59 hydro rated to pull a tractor through wet dirt while carrying a loaded front bucket is ever going to see anything close to the same resistance in snow and ice....chains or no chains. And that's partly why I've justified using front chains on my last three 4WD tractors. That, and the convenience factor. Front chains are wonderfully easy to get on and off.
But there's also no reason to be dumb about chains. I use a cross link configuration to get that lateral traction you are looking for, and I make mine fit the tires real well to make sure of enough clearance when turning sharply. BTW, turning interference is my guess as to why Kubota is worried about front chains.
To farther limit torque on the front drive, don't use chains with claws or bars and don't force things with the chains on.
Finally, think about the mechanical consequences. Turns out it's not too bad. The front drive should be designed to be "fused" via the front drive shaft. And the rest of the systems are independent.
Good luck with it,
rScotty - colorado
/ Tire Chains on M59 #4
I've run chains on 4WD tractors for 25+ years and have never had a problem. I know lots farmers and small scale loggers that have used chains on 4WD tractors for years and have never heard them have a problem because of it. And I don't recall ever seeing someone post a message on TractorByNet indicating that their front drive was damaged by the use of chains (though your question has been raised many, many times on TractorByNet). That said, I think you'll probably be okay using chains on front.
/ Tire Chains on M59 #5
I won't say for the M 59 specifically, however, I will say for the last 50-60 years, around this AO, that all contractors and local, county and state highway dept, use St Pierre "rollers" on the fronts only. I have never heard and I have asked others and they have never once heard of ruining a front end component using the St Pierre roller system,, As stated, the chains are constantly rolling around the tire tread and are actually loose,, ,,
So I am interested. Can you post a picture of the St Pierre "rollers". I have never heard of them.
Also I run chains on all 4 tires.
/ Tire Chains on M59 #6
Search my threads about chains on L48s. Not impossible, but pain i the arse. Here is one of mine chained up:
/ Tire Chains on M59 #7
I chain my front tires on my New Holland hydro TC33D for 10 years now. I have V-Bar's for bad ice , down to the woodpile trips and regular links for other nasty conditions. No problems after 1100 hard hours. The professors here know , there is some % slip built in to these things between the axles, before they are pulling on one another. My solution of chaining only the fronts has been great. Easy on / off using loader to get em off the ground. Frt chains Much lighter to handle than rears due to size difference. My machine has climbed out of very nasty icy grades with frt chains only. Fronts are easy to put on in the field too, on an incline, when the machine is stuck .
/ Tire Chains on M59 #8
Welllll, unfortunately I did not read this thread before I bought a set of rears chains for my M59. I installed them today and realized theres not much room between the chain in the wheel well/fender, in fact it hits some links when spinning. :((( Anyone have any suggestions on the remedy or am I stuck buying the spacers which I didn't even know existed. Any input would be greatly appreciated
/ Tire Chains on M59 #9
Here's one place that makes spacers for your M series tractors.
Kubota John Deere Compact Tractor Utility Vehicle Wheel Spacers
I believe this company also has spacers. Just need to know your lug count and spacing or give them a call.
https://www.motorsport-tech.com/tractor.html
/ Tire Chains on M59 #10
will do thanks. I just saw inner wheel weights might be a option also so it adds weight and moves the wheel track outwards Thanks again
/ Tire Chains on M59 #11
No it will not workwithout at least another inch spacer.
Kubota sells the long wheel studsseperate. have a plate cutting shop with a plasma cutter make you a set of spacer/ weights The stud holes can be key-holed, they do not have to be a circle, you can get weights spacers all it one.
M59 has a stout front axle, so you can get away with front chains like the Chain & Wire Rope | chains, call them ask for Rick.
/ Tire Chains on M59 #12
Well, no real remedies....just some thoughts.
Front chains are sure much easier to put on. Lighter too. A set or rears can be a real wrestling match. You can lift the tractor to put on rears by using the outriggers, but will still have to crawl around to the back side of the tire to fasten the inside chain.
A set of front chains will cost less than the rear spacers. My fronts cost a couple hundred bucks custom made to fit the flat shape of the M59s industrial tires. In average use I've not heard of front chains causing any problem with 4WD tractors. I've used them for 30+ years on many machines for simple work like clearing driveways. But if I was doing commercial type work all day I'd probably go to rears myself.
IMHO, chaining up both the fronts and rears so that the machine can't slip a tire if it needs to is asking for a drive train problem.
If you use rear chains on the M59 you will have to space the wheel out from the inner fender wall....but there still isn't much room between tire and the outer part of the fender.
Chain prices go with the size/type chain and the over-the-tire pattern. My own preference is for a medium/soft steel chain without bars or cleats. On pattern, if it's just for deep snow than any pattern works the same. If the chains are used on a icy slope where side slippage is a problem then an "X" pattern is better than a simple ladder or "H" pattern.
Starting out with H pattern chins is nice because it is easier to make a set of H pattern chains that fit well than any other configuration.....and then as you modify the center link of the H pattern and maybe spread the legs to get it to fit just right it does tend to morph towards an X pattern shape. And that's all to the good.
Before I bought this custom set of fronts for the M59, I'd never bought a set of new chains that didn't need some re-positioning of the cross links and tweaking of the link spacing to make them fit right for the tires. The object there being to make the chains fit well enough so that they won't walk around the tire or slap the tractor. No point in eating up the tractor or the tire.
If I were in your shoes I'd probably get a used set of standard old-fashioned automotive chains and put a little work into fitting them to the front tires on the M59. See how they work. Leave the rears hanging in the barn for that once-a-decade snow storm.
Luck, rScotty
