Screw In Tire Studs
   / Screw In Tire Studs #2
Try using your steering brakes.
I dont think small studs would hold the front end very well
but they might.
   / Screw In Tire Studs #3
For me, even if they did work, I wouldn't want them in/on all the time. Seems the very few times front chains are needed, they are soon taken off. Hard to do that with the studs.
Twice this winter I've had the front tire chains on, but the snow/ice conditions changed within a day each time, so the chains came off.
But please do let us know how you like them, and how well they work. That would be good information to have.
   / Screw In Tire Studs #4
When I had a Gravely with Ag tires, I screwed some metal screws into the outer part of the lugs. Do a search here, and you'll find statements of people using metal screws in motorcycle tires to race them on the ice.
Just measure the depth of your lugs and buy screws no longer than that.
Ralph
   / Screw In Tire Studs #5
We have found that the MaxiGrip studs work well on front tractor tire applications. Many tractor manufacturers will void their warrantee on the front end differential if chains are used. Studs are easily installed and removed with the included tool in each package. Simply keep them in a coffee can during the spring, summer and fall months and re-install for winter. More information can be found on the Manufacterers website at MAXIGRIP ICE STUDS | Tire Studs | Winter Studs and retail pricing at Buy Tire Chains & Snow Chains from the Traction Specialists©.
   / Screw In Tire Studs #6
tractionguru
Is this your company?
We have found that the MaxiGrip studs work well on front tractor tire applications. Many tractor manufacturers will void their warrantee on the front end differential if chains are used. Studs are easily installed and removed with the included tool in each package. Simply keep them in a coffee can during the spring, summer and fall months and re-install for winter. More information can be found on the Manufacterers website at MAXIGRIP ICE STUDS | Tire Studs | Winter Studs and retail pricing at Buy Tire Chains & Snow Chains from the Traction Specialistsゥ.
You don't happen to work at Wallingford's Inc. in Oakland, Maine do you ?
   / Screw In Tire Studs #8
no, but I've done alot of business with them. They always seem to have a solution to any application that I run accross.
   / Screw In Tire Studs #9
For extra steering traction, do you have an option to add extra front end weight?
   / Screw In Tire Studs #10
About tractionguru:
............Maine
Interests
............Plowing snow
Occupation
............Sales
Getting free advertisement... Priceless!!! :D :p
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
2018 HINO 338 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 HINO 338 26FT...
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
