B7510 HST Starting Problem
/ B7510 HST Starting Problem #1
ky_madman
Southeastern Kentucky
Kubota B7510 HST
Tractor wouldn't start, let it set a day and it started. Started fine for 3 weeks. Now, for the last two weeks I can't get it to start. Crossed selanoid, and checked all 5 safety switches. Haven't checked the starter or key switch. Any suggestions. The dealer said that it might be a dirty connection, but I cleaned with a file and wd40 and they seem to be fine. Any suggestions are appreciated it.
Thanks,
Ky_Madman
/ B7510 HST Starting Problem #2
Does it just not turn over? Does the relay or fuel pump click? Or is it doing nothing at all? Any more info you can give may help with suggestions.
It clicks when you turn the key to warm the glow plugs, but from there it does nothing
/ B7510 HST Starting Problem #4
I assume it started when you used a jumper wire from the battery to the solenoid. If so, then it could be low voltage to the solenoid. That was the problem on my F2400. I put a relay in the solenoid circuit and the problem was solved. The SPDT switch is optional. Relays and sockets are available at most auto electric stores.
/ B7510 HST Starting Problem #5
Try grounding the battery to the engine block. My L3650 had the same problem and it turned out to be that the usual ground to the frame was not solid enough. Try it with a jumper cable first to see if it make a difference.
Okay,
I'll try that tomorrow and see if it helps. If not, I'll look into the relay.
Thanks again,
appreciate the help
/ B7510 HST Starting Problem #7
Thanks,
Ky_Madman
Rock your HST pedal and allow it to find it's neutral position. Often these switches are the culprit and can be resolved with foot movement or hand movement to allow the switch's safety position to reposition itself. They can be delicate or cantankerous but be patient. There are a lot of posts on this issue, if indeed this is the problem.
/ B7510 HST Starting Problem #8
If this doesn't solve the problem, check the PTO lever. I bump mine all time and have the same problem. The first time took a while to figure out. In almost 5 years have never had the problem with the HST switch.
It sure sounds like a safety switch to me. I am not aware of anyone having a low voltage problem with a B7510.
/ B7510 HST Starting Problem #9
I second the HST AND the PTO lever issue...both happened to me...
/ B7510 HST Starting Problem #11
The ground wire to chassis or engine is often overlooked. My car wouldn't start reliably sometime even though all voltages at the start switch and the solenoid were OK. One time the car wouldn't start at all as I held the key in start position I smelled burning plastic smell. When I opened the hood the choke cable was smoking and the plastic covering it was all melted. The cable was apparently single connection from the chassis to the engine so all the starting current passed trough it. The strap connecting the engine to chassis was loose and didn't provide sufficient connection to engine. After I tightened it started right away.
Measure voltage between the started body and the minus pole of the battery while a helper tries to start the engine. There should be small voltage drop. If there is not voltage drop at all then there is not power on the starter. If the voltage drop is large then the you have bad ground connection.
Do as somebody already suggested connect the body of the starter to the minus (the pole connected to the chassis) of the battery.
PALLET OF RAMPS (A68842)
PALLET OF RAMPS...
PORTA POTTY (A68842)
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2025 XKH39 39in Hydraulic 4-Way Clamshell Bucket Mini Skid Steer Attachment (A66734)
2025 XKH39 39in...
2019 Ford F-450 Knapheide Crew Cab Service Truck (A66736)
2019 Ford F-450...
2017 FORD F550 4X2 S/A SERVICE BODY TRUCK (A67737)
2017 FORD F550 4X2...
