wench
/ wench #41
Guess I just don't understand how a legged winch would provide and 'anchor', and not just pull the tractor rearward. Perhaps it's designed for a 'track' machine? ~Scotty
/ wench #42
I've seen both types, the ones with legs are mostly older winches. A friend of mine has one with legs, works fine for him. Personally, I'd sooner have the blade. It's likely an older Norse.
Chilly
/ wench
Is it possibly a Norse? I have an old one, a 2500, with legs. The pic attached shows a receiver carrier I use in the woods, but you can see the winch also. This never had a blade, though they were optional then. I've thought about adding a blade but I use the 2" receiver too much and the blade would limit how low it could go to catch a trailer pintle.
Jim
so far this is the closes i have seen the only difference is the legs on mine are bigger ...........thanks jimmysisson
/ wench
THANKS TOO EVERY ONE THAT HELPED ME OUT :D:D:D
/ wench
it is different:confused: but the legs have little graber grubers plats...??????...under the legs :confused:
2023 PETERBILT 367 (A63569)
2023 PETERBILT 367...
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
2022 LINCOLN  VANTAGE 549X (A63569)
2022 LINCOLN...
2006 Volvo Semi (A64047)
2006 Volvo Semi...
SDLGC100 Golf Cart (A64047)
SDLGC100 Golf Cart...
John Deere 6125R Tractor (A64047)
John Deere 6125R...
