Chains Are chains the answer?
   / Are chains the answer? #1
Sideways
Southern Maryland
I had some issues plowing/moving snow this weekend with my Iseki TX1500.
It seemed everytime I filled up the FEL my back tires would spin on the pavement, basicly getting stuck in my own tracks.
If I dumped the load I could move.
My rear tires are not filled but I did have my tiller attached as counterweight.
Would chains have stopped the rear tires from spinning or is filling the rear tires a better option?
Yes, I am a newbie :D
   / Are chains the answer? #2
It might depend on which type of tire you have. R4's dont have as much traction in snow and ice as turf tires. R1's are a little better than R4's in snow. R1's sometimes don't benefit as much from chains because the chains sometimes get into the voids. But in all tire types, chains do help.
The full loader made you heavy on the fronts and light on the rears, and after you dumped, then the weight evened out.
My guess is if you were to only do one thing, more weight or chains, I would go with chains. Both more weight and chains would probably be ideal.
   / Are chains the answer? #3
Could you find something heavy to hang on the back to try it out? Chains won't help too much with no weight on them, I don't think, and they will gouge up pavement.
Depends on what you are plowing grade-wise and how often do you plow snow. In snowy places on any kind of grade, I would do both chains and rear weight, it doesn't have to come from filled tires.
Dave.
   / Are chains the answer? #4
Sounds like a ballast problem to me.
What type of tires do you have.?? How much does your tiller weigh.??
When your bucket was full did your front tires look flat.?? If so, that is a lot of weight on your front end.
In any event, I think you need more weight on the back end. I have a ballast box filled with cement which weighs about 600lbs....I assume you have a 3pt. hitch.??
Chains would help some but I really think you need weight, in which filling your tires with liquid would solve the problem. Be careful of which liquid you use. Some liquid can cause damage to your rims.
Here is a picture of my tractor with the box blade attached.
Not sure of the exact weight of the tiller but I would guess 250lbs.
JD, the front tires did not appear flat when the FEL was full.
   / Are chains the answer? #7
The tires look like rice paddy tires.
Where are you located?
Get some windshield washer fluid, drop the tires on the ground, break the top bead (valve stem up), pour in the fluid, prop the tire up to close the bead, and put air in to desired pressure.
Or load that box blade down with some heavy weight. Shoot for another 500 to 750 # to make a good ballast.
   / Are chains the answer? #8
Gotta agree with Beenthere, with those 'rice paddy' tires, chains won't help alot. Get them filled and/or more ballast.
   / Are chains the answer? #9
No one mentioned tire air pressure? Try letting some out let the sidewall bulge a little, A really hard Tire has no bite at max inflation! Then try weight and chains , we get lots of ice in NY , I run all 4 chained up with no weight the tractor is unstoppable! 2 link spacing is key!
   / Are chains the answer? #10
My b3030 was terrible in icy conditions while plowing w/ R4's. Loaded tires this year and it's now like a new machine.
   / Are chains the answer? #11
" plowing w/ R4's. Loaded tires this year and it's now like a new machine. "
Same here,also easy on the pedal when backing out not to spin the tires.
   / Are chains the answer? #12
weight to help with keeping the tire on the ground. Chains to dig into ice and get traction. Can't beat the compo especially when plowing snow. Reminder please only use chains on the rears. I know some folks say they work on the front. The tractor is not disigned to have that much forced slammed onto the front drive.
   / Are chains the answer? #13
My 4010, which is probably about the same weight as your Iseki, was fine with loaded turf tires. I only had to watch about putting more than one tire off the pavement when dumping the FEL. Long as I kept 3 tires on the pavement, it was fine. Otherwise, I had to lower the FEL, blade down and do an upcurl to get back onto the pavement.
I hauled about 22 tons of gravel with my 4010 early in its life. I put a heavy attachment on the back for that. In the snow, it was just my lightweight back blade.
Ralph
   / Are chains the answer? #14
Hi there Sideways, welcome to the world of tractors. I have a Mahindra 2810HST with a FEL. I have a deep bucket on the front most of the time for snow and a rear mount 3pt hitch blower. I have never used chains nor would I put them on my tractor. My tires are not loaded because of the other seasons work we do. I move a lot of snow with my rig in the winter just as it came from the dealer. I think after considering your problem I would check the front axle to make sure it is engaged. Also I would stay with the box blade for ballast. Good luck. . . John
Thanks everyone!
Certainly alot more options/soultions than I thought of, especially lowering the air pressure. I will give that a shot first then filling the tires and adding more ballast to the rear
Thanks again!
   / Are chains the answer? #16
its 4x4, it should move even with the rear off the ground. just put some weight on the rear and you'll be fine.
   / Are chains the answer? #17
Thanks for the word of caution Mr. 2020,
I had flipped my B7800 front wheels around (tire valves on the inside) and from side to side to get enough clearance for front chains. My trusty Kubota dealer said nothing when I told him I wanted to do this so as to run chains on the front end all winter. I plowed twice so far, works like a charm. On the other hand, the ride is very lumpy (steering wheel jumps radically) I was considering removing the front chains. The fact that I paid a small fortune for the chains in the first place is what is driving me to keep them on the front.
Reading your warning this am, there're coming off this morning, thanks again for confirming what I thought might be the right thing to do.
Dan
Ps: I love this site don't you all?
   / Are chains the answer? #18
My B7610 has R4's, which ARE loaded with WWF, and they still suck in icy conditions. I had turfs on my B7100, which were way better.
   / Are chains the answer? #19
Be really careful about lowering the air pressure, as it can lead to a spun tire syndrome, which I am sure you understand.
+1 on this being almost entirely being a balance issue.
   / Are chains the answer? #20
You do not want to lower the tire pressure too much, but they might be over inflated now. The entire width of the tire bars should be touching the ground as the tire rolls. In other words, when you stand to the side of the tractor, the bars as they roll against the ground should be flat on the ground to their outside edges and not curled up off the ground due to high tire pressure. Lowering tire pressure to the proper amount will increase the surface area touching the ground, and improve traction. It will also extend the life of your tires since they will wear more evenly and spin less.
Massey Ferguson 9250 (A56438)
Massey Ferguson...
Cushman Cart (A59231)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
207277 (A52708)
207277 (A52708)
