Grapple Dehnerwelding Grapple dialup warning
/ Dehnerwelding Grapple dialup warning #1
Thumper & Buttercup
Gold Member
North Dakota
NH T2220
Hey Guys,
We'll Christmas came early this year for me.
I am making a new post for this so others can find it easier. You guys will have to thank my wife for some of these photos, she braved the cold to take them while I did the unloading.
I took these photos so you guys could better see it, their website is nice but their photos do not do it justice. This is their 60" grapple, the shipping manifest shows a weight of 440 lbs. Between my forks and it I could feel the rear of the tractor go a little light when I lowered it so there is some weight there.
I will not get to use this until spring but I think this style Grapple will do everything we want and more. Hope you guys enjoy.
Unloading from the truck. While I am backing up I see the driver laughing, he told the wife nice tractor and she said this one is mine, then she pointed out the DX60 with the cab in the shop and said that is his, and that I make her work out in the hot and cold:D.
Side View
Back View (I checked the quick attach measurements and they were fine)
Front View
/ Dehnerwelding Grapple dialup warning #3
Nice..real nice:)
"but not until spring"..gotta try that beast out.;)
Hey Thomas,
I've got to get the Hyd kit for the Grapple installed before I can put her to work. I'm going to get the WRLong kit, but first the T2220 has to go into the shop, it has a leak down on the loader. If I lock it out it's good so they said it's in the tractor. I'll add a rear Hyd hookup and the grapple setup this spring.
Mark
/ Dehnerwelding Grapple dialup warning #5
Nice grapple and nice forks too! Get that WR Long kit installed soon. I think you're gonna love that grapple.
BTW: Do the forks fit on your DX60 as well?
Hey jinman,
Both tractors have the same quick attach so everything fits both tractors. With the temps we've been having below 0 not much shop time, we've got an area I call my oxygen tent that has a propane heater. I can heat that area up enough that it's warm enough to work without a coat but I only use it for emergency's.
My dealer quoted about $250 each to mount a rear hyd connector and another $250+ to mount the WR Long kit, so we will be doing them ourselves come March or April depending on the spring. I am going to call them and make sure they make a kit for our tractor.
I'm not sure but I think I'll have to put a longer Hyd hose on the front connection but I won't know until I hook it up and test it. I'm going to get one of those front mount plates for the hoses also.
A bit warmer today so I told the wife we should do a fit check and check the grapple over just to make sure it's ok:D.
So we went out and moved things around and got these shots, I don't know who did the welding but it's really nice. Here are a few shots from underneath and the Grapple mount.
/ Dehnerwelding Grapple dialup warning #8
This is maybe a little rude but I would like to make some comparisons to the Markham LD-48 grapple that I have:
-Has grease-able pins/bushings welded in vs. the hitch pins in drilled steel
-Has a welded cylinder (USA made-not sure about the one on yours)
-Has a shield covering the piston rod
-Has "teeth" cut into edges for better gripping power
-The bottom tines are curved to allow you to get under stuff better
Hey Kennyd,
Not being rude at all, the cylinder has the Chief Name made by the Bailey International (they are made in Knoxville TN). There is a bar underneath it, but for the brush and small trees and trimmings we are after I don't see a problem.
Yep I saw that it did not have the grease-able inserts but I liked the straight tines for slipping under brush and trees and picking up small rocks. We'll see how good it does in the spring time but it looks like it will do just I wanted.
I forgot the biggest reason we went with this one its over 300 lbs lighter.
/ Dehnerwelding Grapple dialup warning #10
i like how close your tines are, should help keep the smaller limbs from falling through. i'm sure your itchin to use that beast.:D
Hey Bri,
The wife is already trying to figure out how to add some fencing with zip strips or something so we could pick up some of the smaller rocks after we work up the ground. Trying to save the backs as much as possible:D.
If anyone has any idea's on the screen let me know, I figure after it's worked up ok just a couple zips across the front and a couple on the rear would let us sift the loose dirt pretty easy.
I had looked at a rock bucket with more tines but it weighted a ton and we were trying to cut the weight down.
/ Dehnerwelding Grapple dialup warning #12
Hey Bri,
Maybe some heavy duty hardware cloth I think its called. Usually can get it with 1/2" to 3/4" openings in the weave. Probably have to wrap it around the outside tines and wire it down good. Most likely wont work but that's all I got.
/ Dehnerwelding Grapple dialup warning #13
How dare the carrier stick pro stickers all over that! Darn truck drivers....
E
/ Dehnerwelding Grapple dialup warning #14
You might give a piece of expanded metal a try.
Its tough but should be easy to attach and is available in different thicknesses and openings.
/ Dehnerwelding Grapple dialup warning #15
Two sections of cow panel crosshatched with each other and tied to the grapple with u-bolts should make a very durable basket for rocks. if you put a section of welded wire 2" x 4" sandwiched between them, even small rocks won't fall through. The whole thing should be light enough that it's easily handled when installing or removing. Remember, if you want to shake the basket and clear any dirt, the openings can't be too small.
/ Dehnerwelding Grapple dialup warning #16
Probably not a fair comparision...the Markham is a whole other class of grapple, IMHO.
Hey Kenny,
I think what he means and I am not trying to put words in anyone's mouth is, this is a light weight grapple for guys who have a tractor like ours that is only 35 hp. It's not a grapple for a guy who has a 60 hp tractor or bobcat that wants to work it everyday with big or heavy jobs or in a business.
This is a less expensive unit, I got mine for a little over $800 + shipping on ebay. There are more tines, straight to go under brush, it is another choice for someone like us that just needs one for light work every now and then around the farm.
For me if I have something heaver to move I've got my forks. Like I said its over 300 lbs lighter so I've got more lifting capacity with this one over another unit.
/ Dehnerwelding Grapple dialup warning #19
Hey Kenny,
OK, The Markham is:
-Under $1000.00
-Designed for smaller machines
-The LD in LD-48 means "light duty"
-It does have a lot less tines, but they are taller I think and also 3/8" thick
-Said to weigh 385 lbs.
Pretty comparable I think...not "a different class" Maybe he thinks I have the big SSL grapple they offer? The pictures in the link above showing the grapple on the tractor are mine.
/ Dehnerwelding Grapple dialup warning #20
Expanded metal is the 'screening' you'll want to use! Diamond shape, but pricey! Your going to love the 'grapple' capability! Merry Christmas! Ho, Ho, Ho!!!!~Scotty
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Unused 2021 CID POTSS Skid Steer Quick Attach Conversion Tractor Attachment (A66734)
Unused 2021 CID...
2022 WESTERNSTAR DAYCAB 4700 CONCRETE MIXER TRUCK (A67714)
2022 WESTERNSTAR...
2014 FORD F-150 (A67714)
2014 FORD F-150...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2017 TRAILEZE TE80 HTS LOWBOY (A65057)
2017 TRAILEZE TE80...
